T6963 LCD code
Using raymans code for a guide, I am attempting to do some assembly routines for the t6963. I am having typical lcd syndrome which means the screen stays blank. His code works so I know my connections are good. If someone has the patience to look at this it would be appreciated.
I hope you are ok with this Rayman as I am posting your code here.
My code has some additions and I know it is not ready to go but it should at least create a flashing cursor with what I have here.
How about the bias voltage, is it woring properly (so activated after you initialize the display ?). I played (the display played with me, actually) with these displays quite a bit. It took me kilo-hours to make them work. So I settled for a bitmapped mirror in graphics mode. Updated every now and then (50 ms). It works ok. I can post the code. Yours looks ok to me, I also have some logic analyzer dumps of the control signals that I made when It did work (not always!), it includes initialization.
One note: In 6x8 font mode, the graphic screen will use only the lower 6 bits of each byte. So one line will be 40 bytes (for 240 pixels). In 8x8 font mode it will use all the bits, so only 30 bytes are needed. Sorry if you knew that. I didn't.
Here is my code, it includes what I said plus a font, similar to the Speccy's.
I hope it helps. Let me know if you need the dumps because I have them in a machine at work
Post Edited (Ale) : 12/30/2008 11:54:23 AM GMT
outa[noparse][[/noparse]DataBasePin..DataEndPin]:=cmd
With the above command I would understand that it will be reversed, not?
Do you recall any critical necessary delays in the read/writes?
Timing is not so critical, meaning there are setup and hold times as well as minimum widths (some 200 ns) but the 50 ns between instructions are enough for the setup and hold. The CS minimum width for what I saw in your code is taken care of (you call delay). You can have a look at my code, it works. The delays where implemented with nops. It may be a bit long... but it is everything that COG does, so it is ok for me.
I tried hard wiring the lines through 1K resistors high low to just see if this thing would print anything but no luck just some very strange things, I tried Rays code but with my Scope connected to the control pins wr,rd,6,ce,cd nothing seems to change , Ray does say in his code"""'You must manually set pin Numbers in the driver at this time!!!! """ but I couldnt get him to expand on what he meant . the Spark Fun Tech said he email me some "corrected" data sheets and a simple interface schematic with code for the stamp so I can at least verify if my unit is any good , I will post it for everyone when I get it. I guess more that few people here have purchased this display I would love to see one running.
PA7 = WR*
PA6 = RD*
PA5 = CS*
PA4 = CD (A0)
PA8..PA15 = D0..D7
These definitions are at the beggining of the HugeLCDDriver1.spin file.
Those are the ones you should change if you connect your LCD to other pins.
Be careful with the bias voltage, it should not be applied before VCC is.
The *RES signal can be driven with a simple 10uF/10 k resistor, the *RES is connected to the middle, VCC to the resitor end and GND to the negative of the capacitor. That worked for me.
Once initialized it should display the garbage that is in RAM.
Oh Ale for PA5 = CS* Do you mean CE????? I could not find a CS outout
Hey Ale in a last ditch effort and total frustration I swapped pins and put WR=4 CE=6 CD=7 and RD=5 prop pins
and all of a suuden the darn thing did somehting when I run Rays code I get a blinking cursor in the upper left cornner
I also wired up the Res the way you said and tried pulling a couple of the data lines off and manually setting them high or low and it is printing garbage to the screen !!! I am quite pleased ,, I hate to keep bugging but does this make any sense to you??? If I put my scope on the control pins WR,CE,CD,RD· prop pins 6 and 7 are outputing square wave on the scope whenb I run rays code
could I have had the pins wrong all this time??
PIN SYMBOL FUNCTION
1·FG FRAME GROUND
2 Vss Power Supply(GND)
3 Vdd Power Supply For Logic(+5V)
4 Vo Power Supply For LCD Driving (Contrast Adjust)
5 VEE NEGATIVE VOLTAGE INPUT/OUTPUT
6 /WR DATA WRITE
7 /RD DATA READl
8 /CE CHIP ENABLE FOR T6963C
9 C/D COMMAND/DATA SELECTION
10 /HALT CLOCK OPERATING STOP SIGNAL
11 /RST RESET T6963C(LOW EFFECTIVE)
12--19 DB0—DB7 DATA BUS
20 NC NO CONNECTION
21 LEDA LED BACKLIGHT POWER SUPPLY(+)(+5V)
Post Edited (mikediv) : 12/31/2008 4:52:49 PM GMT
Modify Ray's code to output just a char, always the same to see if it fills the screen.
