YAT--yet another test
This is a test...
This is a URL link...
This is a code snippet...
...here's the same thing using Phil's code formatter...
Hmmm...why does it think ".str" should be bolded?...doesn't show up that way in prop tool...beggars can't be choosers, I guess.
Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does. Let's try a sentence w/o carriage return to see what line wrapping does.
A list:
...and finally, here's a post-edit.
Post Edited (BR) : 12/29/2008 11:15:48 PM GMT
CON
_clkmode = xtal1 + pll16x ' System clock → 80 MHz
_xinfreq = 5_000_000
OBJ
debug: "SerialMirror" 'Same as fullDuplexSerial, but can also call in subroutines
filter: "filters" 'filter functions
PUB Init
'Start FullDuplexSerial.
waitcnt(clkfreq * 5 + cnt)
Debug.start(31, 30, 0, 57600)
Debug.Str(String("MSG,Initializing...",13))
Debug.Str(String("LABEL,time,timer,x_meas,x_filt,ticks,bwidth, sig",13))
Debug.Str(String("CLEARDATA",13))
main
[b]CON[/b]
[b]_clkmode[/b] = [b]xtal1[/b] + [b]pll16x[/b] ' System clock → 80 MHz
[b]_xinfreq[/b] = 5_000_000
[b]OBJ[/b]
[b]PUB[/b] Init
[b]waitcnt[/b](clkfreq * 5 + [b]cnt[/b])
Debug.[b]Str[/b]([b]String[/b]("MSG,Initializing...",13))
Debug.[b]Str[/b]([b]String[/b]("LABEL,time,timer,x_meas,x_filt,ticks,bwidth, sig",13))
Debug.[b]Str[/b]([b]String[/b]("CLEARDATA",13))
main
A list:
- Mary
- She had a little lamb
- The fleece of aforementioned lamb was white as snow
- And a propensity to follow Mary anywhere
- And everywhere she may go
txt
21B
