Newbie Needs Help!
I am totally new to BASIC, Stamps, programming, etc. but have decided I want to learn on a project I am trying to make. I need some help though...
What I am trying to do:
Build a population clock using Nixie tubes for the numeric display. Basically a clock that, roughly, adds 2.5 units to a pre-defined number once the clock is started.
What I need:
To be pointed in the right direction...
I am thinking that I want to build this using BASIC cause I can program that on my Mac, using MACBS2. Will this work for the above project?
Also, if it will work, what kind of hardware will I need? I am considering getting a development board, BOE, but I would like to use that for other things once this project is done.
Any help with any of this would be great!
Thanks in advance.
Cheers,
Ben
What I need:
Thanks in advance.
Cheers,
Ben
You will need some high voltage transistors to control the Nixie tubes. Someone did a clock using Nixies for the display. Browse through the Completed Projects forum. You may find some schematics you can borrow from.
You can also search the web. One article I found: www.glowbug.nl/neon/HowToDriveNixies.html. There were many others.
What tubes are you using? I have a couple of clocks, a hot tub temp. display, and a kitchen timer all using Nixies for the display. I just love Nixies. [noparse]:)[/noparse]
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
I just got some Russian IN-8's for my Nixie project. Let me ask you this, what would be the best route to go for a total newbie, resistors or the Russian controller chips?
Also, would it be possible to use just 1 BS2 to drive all 10 Nixie tubes? I know there are space limits and variable length limits so I worry that one chip would not be able to handle the 10 digit number.
Right now I am about to order 1 BS2 but not sure what board I would need to put it on in order to drive this clock. I can use the BOE but something permanent would also be good.
Thanks again for all your help!
I think Parallax sells the '595's. There is a great Nuts and Volts colum, available for download, that has a tutorial and sample code and schematic for the cascaded '595 circuit. This is actually a very easy project, just be careful with the high voltage for the nixies. Smarts and fries chips instantly. Don't use a simple xfrmr or doubler to get the high voltage unless you know how to work safely with mains power. Use a switching supply, much safer. Also make sure to use the correct current limiting resistor for your nixies.
If you need help once you get all the parts, make a new thread with nixie in the title. That will catch my eye, "newbie needs help" is a common subject line.
Jonathan
In future posts please try to use a descriptive subject line that tells forum members what your post is about. Take care.
Parallax Engineering
