Dryer Capacitor — Parallax Forums
Dryer Capacitor
william chanwilliam chan Posts: 1,326
edited 2008-12-27 15:37 in General Discussion
My clothes dryer has trouble starting to turn, but will start to turn if I help it with my hand.
I suspect my dryer's cylindrical capacitor is faulty. I think it could be an oil based capacitor.
Can I change it to a square X2 metalized film capacitor? ( i have a lot of these ).
Will it last longer than the oil capacitor?
Thanks.
www.fd.com.my
www.mercedes.com.my
    edited 2008-12-27 14:03
    It does sound like the Motors starter capacitor has failed, though i'm not sure of what electrical regulations you have in the country you live in i'd be tempted to replace like for like as otherwise you will have "modified the design" and whatever legalities that may lead to in the future such as an insurance claim.
    william chan
    NO
    To this if it is a Start Cap you MUST USE A START CAP TYPE ONLY
    If mfd value is over 15 then it·most likely·a start cap ·
    One way to tell if it a Start Cap the mfd value will be something like 50 to 80 mfd or more also it may have bleed down resister on it as well
    You want to make sure that the cap that you use are
    These are a MUST
    ONE····· the same mfd value
    TWO···· the same voltage value or greater···
    THREE···that it is for AC current· meaning that they are for AC·Motors
    Make sure that you mount the cap to the frame of the motor if you can
    also use a terminal cap protector.......>>>>>
    (>>>>This is a rubber cap that goes over the terminal of the cap<<<<<<)·
    ....... This is a must do as well
    I have done many time before with very good results
    Keeping this in mind
    skylight
    .................otherwise you will have "modified the design" and whatever legalities that may lead to in the future such as an insurance claim.
    As long as these values are meet it should work
    I hope this helps
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 12/27/2008 4:06:39 PM GMT
