Engineering Question if you please.
OK, if I have six 1.2 volt DC batteries that are alkaline rechargebles and they are 350mha batteries and I wish to charge them with two 4.5 volt solar cells.
Can i place a simple diode making the current go in only one direction and allow the voltage to be hooked in parallel ? I have done a google search for how to build a rechargeble battery charger from solar cells. But, I have found nothing useful.
Any real engineers or amateurs want to tackle this?
If you're using standard NiCd or NiMH batteries, these are designed to be charged indefinitely at a 10% rate. If they're 350 mAh cells, you can charge them at 35mA without any special care. Two 4.5V solar cells is probably not enough. Your battery's rating is 1.2V, and 6 in series would require 7.2V. Add a diode drop (0.7V) and you get 7.9V. The batteries probably have a terminal voltage higher than 1.2V near full charge, say 1.5V. Your solar panels would probably reach 4.5V only near full mid-day light levels in direct sunlight. I suspect you'll need 3 x 4.5V solar panels with some kind of current regulator like an LM7805 as described in most LM78xx datasheets.
I was wrong. They are NiMH batteries.
Post Edited (MovieMaker) : 12/27/2008 4:14:27 PM GMT
