10 Mhz crystal question
i was wondering if the propellor could be safely run with a 10 Mhz crystal with a clock multiplier of 16, will it get hotter, what about problems with accessing ram(i have read that this can be a problem if you run it to fast)
Jim
Post Edited (Mike Green) : 12/26/2008 9:55:01 PM GMT
but someone has done some re-organizing and now I can't located it.
Anyone got the link?
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
The break-point under 'normal operating conditions' seems to be around 120MHz. I've had success and no failures at just short of 120MHz, 7.3728MHz + PLL16x and 14.31818MHz + PLL8x using an unmodified ProtoBoard but others have not had perfect operation.
It may be that the prop will run at higher speed but the oscillator won't, or has a poor output waveform that upsets the prop.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
...hippy!!? HIPPY's back! Wondering when you might wander back this direction. [noparse]:)[/noparse]
OBC
