Using FullDuplexSerial with a single wire
DiverBob
I have coded a MCP12F683 (4 channel ADC - 8 pin chip) to send 4 channel ADC information to the uOled-96. So far it has been a one-way download only, with the ADC continously sending the data every 1 second, but due to the current draw I want to code a signal to start the ADC process and have the ADC in sleep mode while not needed. Before I dive into changing the code for this, is there any advice from someone who has tried this before (example code always appreciated - why re-invent the wheel)? I am tying the IO line to VCC via a 4.7K resistor and the line itself is going through a resistor prior to going into the prop, otherwise it is a direct connection between the two processors. On the 12F683 side I am programming it using PicBasic Pro and have been using the DEBUG command to transfer data at 2400 baud (I know, slow but speed isn't the issue here, power consumption is!). I plan on using the DEBUGIN command to read the output from the prop.
Thanks for any help
Bob Sweeney
Thanks for any help
Bob Sweeney
you can use the fullduplexserial-object (FDS) with one wire
you define the same pin for tx and rx and use mode 4
the FDS has four modes of operation
it is described in the sourcecode
take a look into this thread
http://forums.parallax.com/showthread.php?p=680429
best regards
Stefan
Post Edited (StefanL38) : 12/26/2008 10:54:17 AM GMT
I'll try this out later today and report back on my success (thinking positively!)
Bob Sweeney
