gun or canon for my robot
I am looking to build a gun or canon n my robot. I have seen the solutions from pob-technology.com regarding there dart gun and have also seen an airsoft gun sitting atop a mobile base. Has anyone ever built some sort of projectile into their robotic application? If so I would like to know what you did and where you got your parts.
Justinrumpf.com
Justinrumpf.com
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Before I give you the reference, let me warn you that this stuff is very addictive! Like you, I asked a question about bb cannon and now my workshop has a collection of balsa, servos, and plans. For a start try this:
http://www.rcnavalcombat.com/rcnavalcombat/forum/
Good luck,
Ron
Here are two links to websites that sell CO2 powered bb cannons:
http://Battlersconnection.com
http://BDErc.com
Battlersconnection.com seems to be cheaper and more user friendly than BDErc.com.
Also, if you want to use air instead of CO2, here is a source for small hobby scale air tanks, air control vales, and accessories: http://www.robart.com/air_systems/airkits.aspx
However, you might want to consider using a fully automatic soft air mini-machinegun that fires a 6mm plastic pellet at round 110-130 ft/sec velocity. At close range they can really sting when hitting the skin. I use them to keep skunks off of my property here in North Texas. The cheap ones are around $20 at Walmart, but the better ones are $50-$200 and last much longer.
Hope this helps.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edited (Tom C) : 12/26/2008 11:56:00 PM GMT
www.montysminiguns.com/AirSoftPage.htm
