Question on BASIC STAMP HomeWork Board - using the servo with wall pack
I have a regulated 9vdc 1amp power supply - couldn't I use this in place of the battery?
thanks in advance and I wont blame anyone for damage! -I will just buy another one
It is not recommended to do so. In the servo application when you’re powering the servo from the 9V battery, it is technically being over-powered. In this case it is for proof-of-concept and while it does reduce the life of the servo some, it is not going to damage it in the short term. Most wall adapters, however, run at higher voltages than what they are rated at when not at full current load. So your 9V wall adapter may be putting out 14-16 volts. And really, anything over 9 volts will pretty much damage the servo. Depending on which revision of the Homework Board you have, you could use the on-board regulator though. If your board is Rev C or higher, you should be able to connect you wall adapter to the 9V terminals and get servo power from VDD. I hope this helps. Take care.
Parallax Engineering
