Can´t get work TV out at basepin P10..Why ??
Hi all
I´m stuck with this stupid problem, I´m connecting the 1.1K, 560 Ohm, and the 270 Ohm R´s, at the pins P10, P11, P12 for video out, but I can´t get work in those pins.
What is happening ?? am I missing something ? or it´s a bug of the driver.
I´m using "TV Text Demo v1.0" from Chip Gracey.
It works fine in pins, (0,1,2), (1,2,3),.... (12,13,14), but wont work in (8,9,10), (9,10,11), (10,11,12).
Thanks in advance.
Regards.
Alberto.
Thanks in advance.
Regards.
Alberto.
Every day I learn something new..I´ve never listen about that limitation, now I´m in a big problem my PCB was done with pins 10, 11, 12.
I suposse there is no way to modify the driver easily, I tried with "tv_pins := (basepin & $38) << 1 | (basepin & 2 == 2) & %0101"
but no luck.
Regards.
Alberto.
Paul Baker
Paul Baker
'Bummer about the board layout. That's a rough pin combination, to be sure. You might get something to work if you're willing to forgo color output. It would involve using pins 8..15 and an 8-bit (VGA) video mode, with all but pins 10..12 masked out. You'd have to modify TV.spin for the unusual arrangement, though, just to generate the proper sync, among other things. In your shoes, I'd redo the board layout. In the end, you won't regret it.
'Just a few PropSTICK Kit bare PCBs left!
Phill you´re right, I´ll redo my PCB... sometimes we´ve to lose, simple solution this time, in the future, I will try a prototype before.
Comments:
I´m testing it in pins (1,2,3), (5,6,7), and it works in a B/W TV
Regards.
Alberto.
Envio editado por (BTX) : 12/22/2008 9:57:31 AM GMT
To save yourself as much grief as possible, lay out your board to use one of the following combinations: 0-2, 4-6, 8-10, 12-14, 16-18, 20-22, or 24-26. If you need broadband video with FM sound, you will need to add the fourth pin in each sequence (e.g. 12-14 becomes 12-15).
Yes, now I know that, before, I thought that any pin was possible for TV out.
Regards.
Alberto.
