Serial data question — Parallax Forums
turboturbo Posts: 24
edited 2008-12-22 06:33 in General Discussion
Ok here goes i have a program that works ok right now but i know it could be alot better if i could figure this out, the program sends data to a instrument panel on a motorcycle, it is 8 bits no parity and 1 stop bit but right now im doing it all wrong i would like some incite on how to go about fixing it.
The program works right now but i have to manually go to a data table to get a different string each time a temperature reading changes and this means i have a huge data table in my code witch eats up valuable space.
Here is some of my code that works right now this is a small fraction of the data im sending out.
You will also notice that the data always has to add up to 512 in order for the dash to work if it 511 or 513 or anything other than 512 it wont work so i need to do a checksum ( i think) to make it work better.
The first bit in the data is for temperature control , so it changes all the time depending on the input from a sensor , and the second bit changes sometimes depending on the status ( ie. error codes) other wise it stays Hex 40 the rest of the bits can be anything as long as it adds up to 512 before it sends it out.
Any help would be appreciated.
C0:
   DATA $C8,$40,$00, $00, $00, $00, $00, $F8,$00
C1:
   DATA $78,$40,$00, $00, $00, $00, $4A, $FE,$00
C2:
   DATA $6E,$40,$00, $00, $00, $00, $54, $FE,$00
C3:
   DATA $64,$40,$00, $00, $00, $00, $5E, $FE,$00
c4:
   DATA $4B,$40,$00, $00, $00, $00, $77, $FE,$00
C5:
   DATA $41,$40,$00, $00, $00, $00, $81, $FE,$0
'DATA   $64, $F5, $00, $1, $00, $00, $B, $9B,$00
 'DATA   $64, $F5, $00, $2, $00, $00, $B, $9A,$00
 'DATA   $64, $F5, $00, $3, $00, $00, $B, $99,$00
 'DATA   $64, $FF, $00, $4, $00, $00, $B, $8E,$00
 'DATA   $64, $FF, $00, $5, $00, $00, $B, $8D,$00
 'DATA   $64, $FF, $00, $6, $00, $00, $B, $8C,$00
 'DATA   $64, $FF, $00, $7, $00, $00, $B, $8B,$00
 'DATA   $64, $FF, $00, $9, $00, $00, $B, $89,$00
 'DATA   $64, $FF, $00, $A, $00, $00, $B, $88,$00
 'DATA   $64, $FF, $00, $B, $00, $00, $B, $87,$00
 'DATA   $64, $FF, $00, $D, $00, $00, $B, $85,$00
 'DATA   $64, $FF, $00, $F, $00, $00, $B, $83,$00
 'DATA   $64, $FF, $00, $11, $00, $00, $B, $81,$0
  • BeanBean Posts: 8,129
    edited 2008-12-21 13:35
    Do you have a datasheet for the device you are communicating with ?
    Bean.
    "The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
    www.iElectronicDesigns.com
  • turboturbo Posts: 24
    edited 2008-12-21 14:05
    No this is a stock dash for a bike and im not exactly sure witch chip inside of it im actually talking too, it works right now all im doing is sending data to it i dont have to worry about getting any data back , it runs at 7812 baud and about every 250ms or so on the transmission its not too picky. This is a 1 wire transmission setup.
  • JonnyMacJonnyMac Posts: 9,545
    edited 2008-12-21 17:57
    Based on the [noparse][[/noparse]very limited] information you've provided I'm guessing that your system wants to send seven data bytes, a checksum byte, then $00. You can put the data bytes into an array and then pass the address of the first byte to the TX_CMD_STR subroutine shown below:
    ' Use: TX_BYTE byte
    SUB TX_BYTE
      SEROUT TX, Baud, __PARAM1
      ENDSUB
    ' Use: TX_CMD_STR strAddr
    ' -- pass address of command array
    SUB TX_CMD_STR
      addr          VAR     tmpB1
      txCount       VAR     tmpB2
      txOut         VAR     __PARAM1
      chkSum        VAR     tmpW1
      addr = __PARAM1                               ' copy address
      chkSum = $200                                 ' reset checksum
      FOR txCount = 0 TO 6
        txOut = __RAM(addr)
        chkSum = chkSum - txOut
        TX_BYTE txOut
        INC addr
      NEXT
      TX_BYTE chkSum_LSB
      TX_BYTE $00
      ENDSUB
    Post Edited (JonnyMac) : 12/21/2008 6:06:30 PM GMT
    edited 2008-12-21 18:24
    Here is some code right now that works minus the ADC routine.
    Basicaly i take a reading from a temp sensor then depending on the reading i go find the "DATA" string that matches the position i need the gauge to read when all i really need to do is change the first bit in the string since the other 7 bits can stay the same now in order to do that i need a way for the program to automatically calculate the checksum of the data to go out.
    This program just keeps sending the same string to th dash unless potval goes above 0 then it changes to another string.
    Now in the real program i use there are MANY strings depending on the temp reading i get from the sensor so i have to keep changing the first bit and then recalculating the total bits to make sure the gauge accepts the string
    [noparse][[/noparse]code] DEVICE SX48, oscxt2'SX28, OSChs1 , TURBO, STACKX, OPTIONX,
    FREQ 20_000_000
    'DEVICE SX28, OSCxt1 , TURBO, STACKX, OPTIONX, 'SX48, OSchs1
    'FREQ 4_000_000
    'DEVICE SX28, OSC4MHZ , TURBO, STACKX, OPTIONX, 'SX48, OSchs1
    'FREQ 4_000_000
    ID "SGI_V1.0"
    ' I/O Pins
    TX PIN RE.4 OUTPUT
    inpin PIN RA.2 INPUT CMOS
    outpin PIN RA.1 OUTPUT
    neutralin PIN RD.7 INPUT
    FI PIN RC.3 INPUT PULLUP
    Potpin PIN RA.0 INPUT
    pot PIN re.6 input pullup
    ' 7 SEGMENT DISPLAY VARIABLES
    A PIN RE.5 OUTPUT
    B PIN RE.3 OUTPUT
    C22 PIN RE.0 OUTPUT
    D PIN RE.1 OUTPUT
    E PIN RE.2 OUTPUT
    F PIN RE.6 OUTPUT
    G PIN RD.7 OUTPUT
    ' GEAR BASED BOOST CONTROL OUTPUTS
    GB1 PIN RB.1 OUTPUT
    GB2 PIN RB.2 OUTPUT
    GB3 PIN RB.3 OUTPUT
    GB4 PIN RB.4 OUTPUT
    GB5 PIN RB.5 OUTPUT
    GB6 PIN RB.6 OUTPUT
    ' Constants
    Baud CON "T7812"
    SAMPLES CON $07
    LcdCC0 CON $F0
    LcdCC1 CON $F1
    LcdCC2 CON $F2
    LcdCC3 CON $F3
    LcdCC4 CON $F4
    LcdCC5 CON $F5
    LcdCC6 CON $F6
    LcdCC7 CON $F7
    LcdCC8 CON $F8 ' define custom char 0
    LcdCC9 CON $F9 ' define custom char 1
    LcdCC10 CON $FA ' define custom char 2
    LcdCC11 CON $FB ' define custom char 3
    LcdCC12 CON $FC ' define custom char 4
    LcdCC13 CON $FD ' define custom char 5
    LcdCC14 CON $FE ' define custom char 6
    LcdCC15 CON $FF ' define custom char 7
    ' Variables
    DATABUFFER VAR BYTE
    AVG VAR BYTE
    tmpW1 VAR Word
    ADC VAR Byte ' adc in from clt sensor
    idx1 VAR Byte ' loop control
    temp1 VAR Byte ' subroutine work vars
    temp2 VAR Byte
    temp3 VAR Byte
    temp4 VAR Byte
    temp5 VAR Byte
    NEW VAR BYTE
    potval VAR Byte
    neutral VAR Byte
    PROGRAM Start
    ' Subroutine / Function Declarations
    CLT_STEP SUB 2 ' define custom character
    DELAY_MS SUB 1, 2 ' shell for PAUSE
    CLT_OUT SUB 1, 2 ' send byte {+ count} to Dash
    ' Program Code
    START:
    High potpin
    Pauseus 35
    RCTIME Potpin, 1, potval, 3 '
    PAUSE 0200
    IF POTVAL = 0 THEN
    clt_step c15
    PAUSE 500
    ENDIF
    if POTVAL >0 THEN
    CLT_STEP C7
    ENDIF
    GOTO start
    ' Subroutine / Function Code
    ' Use: DELAY_MS milliseconds
    ' -- shell for PAUSE
    SUB DELAY_MS
    IF __PARAMCNT = 1 THEN
    tmpW1 = __PARAM1
    ELSE
    tmpW1 = __WPARAM12
    ENDIF
    PAUSE tmpW1
    ENDSUB
    ' Use: CLT_OUT theByte {, count }
    ' -- sends "theByte" to the dash for data [noparse][[/noparse]optional] "count" times
    ' -- "count" defaults to 1 if not specified
    CLT_OUT:
    temp1 = __PARAM1 ' save the byte
    IF __PARAMCNT = 9 THEN ' "count" specified?
    temp2 = __PARAM2 ' yes, save
    ELSE
    temp2 = 1 ' no, set to 1
    ENDIF
    DO WHILE temp2 > 0
    SEROUT Tx, Baud, temp1 ' transmit to LCD
    DEC temp2
    LOOP
    RETURN
    ' Use: CLT_STEP CharDef
    ' -- loads custom character definition into DATA TO DASH FOR CLT GAUGE
    ' -- "CharDef" is DATA table that holds character number and definition
    ' bytes
    CLT_STEP:
    temp3 = __PARAM1 ' get definition offset
    temp4 = __PARAM2 ' get definition base
    FOR idx1 = 1 TO 8
    READ temp4 + temp3, temp5 ' read a byte
    CLT_OUT temp5
    PAUSEUS 3700 ' send the byte
    INC temp3 ' point to next
    temp4 = temp4 + Z ' update base on overflow
    NEXT
    RETURN
    ' User Data
    C0:
    C1:
    C2:
    C3:
    DATA $64,$40,$00, $00, $00, $00, $5E, $FE,$00 'CLEARS THE CLOCK FOR USE clt low
    c4:
    DATA $4B,$40,$00, $00, $00, $00, $77, $FE,$00 'CLEARS THE CLOCK FOR USE clt 1/8
    C5:
    DATA $41,$40,$00, $00, $00, $00, $81, $FE,$00
    c6:
    DATA $32,$40,$00, $00, $00, $00, $90, $FE,$00 'CLEARS THE CLOCK FOR USE clt 3/8
    c7:
    DATA $2D,$40,$00, $00, $00, $00, $95, $FE,$00 'CLEARS THE CLOCK FOR USE clt ALMOST MIDDLE
    c8:
    DATA $1E,$40,$00, $00, $00, $00, $A4, $FE,$00 'CLEARS THE CLOCK FOR USE clt middle
    C9:
    DATA $19,$40,$00, $00, $00, $00, $A9, $FE,$00
    C10:
    DATA $16,$40,$00, $00, $00, $00, $AC, $FE,$00
    c11:
    DATA $12,$40,$00, $00, $00, $00, $B0, $FE,$00 'CLEARS THE CLOCK FOR USE clt 5/8
    c12:
    DATA $11,$40,$00, $00, $00, $00, $B1, $FE,$00 'CLEARS THE CLOCK FOR USE clt 3/4
    C13:
    'DATA $A ,$40,$00, $00, $00, $00, $B8, $FE,$00 'CLEARS THE CLOCK FOR USE clt high light on
    'DATA $F ,$40,$00, $00, $00, $00, $B3, $FE,$00 'CLEARS THE CLOCK FOR USE clt AT RED MARK
    DATA $1E,$80, $00, $E4, $00, $00, $00, $7E,$00 'CLT FULL CLOCK BLINK FI LIGHT ON
    c14:
    'DATA $1E, %11010000, $00, $00, $00, $00, $51, $C1,$00 'CLT LOW AND COO ACROSS DISPLAY
    'DATA $F,$80, $00, $00, $00, $00, $73, $FE,$00 'CLT 1/8 CLOCK BLINK
    c15:
    DATA $64, $A, $00, $E5, $00, $00, $B, $A2,$00 'CLT LOW SETS THE FI ON THE DISPLAY AND BLINKS THE LIGHT
    For example for DATA C11 the bit $12 will make my coolant gauge read 5/8, now on DATA C3 $64 will make my gauge read low , the second bit $40 clears error codes off a lcd in the dash it is the same through all my strings unless there is a error code to be displayed then it will change to whatever the error code that needs to be displayed is ( not totally necessary i dont have to have this) C15 you will see the second bit is $A this will set a error code on the lcd.
    edited 2008-12-21 18:34
    You could use READ with an offset to get your first byte, send the middle group as known bytes, then the variable checksum -- this would simplify the code a bit (I think) and remove a lot of redundant code from tables. That said, a lot of this is technical guessing without a proper spec.
    Thanks for the input your example helped me out i got it to calculate the checksum and it seems to be working now , it seems to be working off of 256 as the total bit count just fine also i guess i was just doubling the byte count before with 512 ( im new to all this show im a little slow LOL ) .
    It never dawned on me till i looked at the example code from you Jonny how you calculated the check sum how to do it.
    Anyway thanks for the great help !!!
