Neural Networks — Parallax Forums
Neural Networks
General CedricGeneral Cedric Posts: 18
edited 2008-12-22 21:19 in General Discussion
Has anybody here used a neural network to control a robot? I was thinking about using a neural netowrk programmed in python.
-General Cedric
"Wikipedia is your Friend"-Me
    edited 2008-12-19 20:45
    What hardware (CPU) are you going to use? Neural nets of any size require a lot of processing power, and using python (or any other interpreted language) would multiply that requirement.
  • LeonLeon Posts: 7,620
    edited 2008-12-19 21:35
    That is true for the training phase. Once the network is trained, though, it can run on much less powerful hardware.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • soshimososhimo Posts: 215
    edited 2008-12-20 00:03
    What are you using for an activation function in your hidden layer? If you are using sigmoid or some other non-linear function then you will definitely be slamming the processor. Remember, you don't have a dedicated math coprocessor so all those floating point calculations are going to take memory and/or cycles. If you go with a step function then you are limited to only a perceptron type NN which usually has binary classification (no fuzziness). I've tried to get a NN to run on a PIC uController which has a lot more RAM than the Prop and pretty much you would have to dedicate a very high-end chip just for the NN itself. At least those were my observations based on RAM and the processing power of the chip itself (which was 33MIPS).
  • LilDiLilDi Posts: 229
    edited 2008-12-22 19:05
    Take a look at the CogniMem. great products, but pricey
    http://www.roadnarrowsrobotics.com/
    At a 110 bucks a pop you don't want to make any mistakes [noparse]:)[/noparse], but they are nice. I was reading the specs, 10us recognition time max (for a 1024 matrix) and they have direct digital video recognition. Can you say true vision? If I ever win the lottery or my boss decides to get a wild hair, maybe...
    Here's a link directly to the chip
