ADXRS300 gyro with BS2px
Technic-R-C
Hello
I am trying to get an ADXRS300 gyro from sparkfun electronics to work with the Parallax BS2px stamp.· Can anyone provide some help with the wiring and a bit of code that can get me started.· All i want is to get the amount of spin the gyro reads and print it on the debug screen...
As for the wiring i think that it is as follows
GND - ground VSS
5V - VDD
Rate - an I/O pin
TEMP, 2.5V, ST1, ST2 ports - i dont believe these are needed but i might be wrong....
heres the datasheet
Technic-R-C
GND - ground VSS
5V - VDD
Rate - an I/O pin
heres the datasheet
Technic-R-C
It outputs an analog signal, so you're going to need to do analog-to-digital conversion. Were it me, I'd use one of the ADC chips like this one
www.parallax.com/Store/Components/IntegratedCircuits/InterfacingChips/tabid/613/CategoryID/78/List/0/SortField/0/Level/a/ProductID/245/Default.aspx
which is cheap ($6) and well documented in various Parallax publications.
