standalone bs2
I have made a enclousre to control a servo, a few relays, and a 7pin led. However on a Basic stamp board all my codeing works fine, however when i use a bs2 chip(not parallax board) my servo freaks out. Any advise?
Your code & hardware works on the factory Basic Stamp board but not on the non-Parallax board. What are you using for the second Board ? I assume that the stand alone micro was pre-programmed before it was inserted on to your second board. Without knowing more, it sounds like you have an improper or a bad connection somewhere on the second board. Double check all of your connection points....
Twisted Pair....
TwistedPair....
i might have the wrong pin connected to the (-) of the battery.....might have crossed on of the wires on my 25-pin conector......retesting
TwistedPair....
TwistedPair....
