Using BS2 to dial a cell phone
Has anyone tried this with the DTMF outputs? It would be mighty handy for remote communication. Maybe get a cheap trackphone and hook up a BS2 to phone home. Thanks for any input. STAMPS RULE!··
·· manzana in Texas
- Stephen
manzana in Franklin, NC
I woulk like to see the schematic how·you are going to connect the BS2 to the phone button. I am on a project·of using my old h phone mp3 player for robotic voice.I am using relay for the button. Still under construction. I will let you know the outcome too.
1. Each button has 2 contacts, an inner circle an an outter ring. One of them is common to all the buttons. Need to determine if the button is grounded or at some voltage when it is closed. This is what the BS2 needs to duplicate. It may take a resistor or 2 to do this.
2. The keypad is close to an RF source which will interfere with the wires you solder (maybe). If it does it is best to use small coaxial wires to go to the BS2 and put a high frequency cap (maybe 12 pf?) at the phone side. This might be not be necessary. Not sure.
3. I think your stamp will want to test if the phone is on or off too. You dont want to lose track of this if the phone is in a remote location. Since the power button is basically a toggle, once you got out of sync it might get expensive!
·3. Once the phone calls you, it needs to say something to you. It would be simple to have it text you or just put a small speaker next to the mike of the phone and send tones from the BS2 or even canned voice. My BS2 uses an RF link now and sends Morse Code. At least I am getting some benefit from 30 years of ham radio.·
manzana, Franklin, NC
Post Edited ($WMc%) : 12/21/2008 11:18:07 PM GMT
This is just my 2 cent worth talking ..........>>>>>>· So take it for what it worth
BTW most cell phones that I have used you can put the· Phone Number in first and then hit·SEND button
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 12/21/2008 2:32:33 AM GMT
The relays that I am using are <A href="http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=1582962&">LBA110</A>) Because my chip has only 16 IO pins I focused on being able to control the 5-button D-Pad and four surrounding buttons (Call, End Call, Left Select, Right Select) (rest of the pins are being used as input) with this configuration I am able to access the menu from wich I can select previously entered text message and/or telephone number.
BTW in my program the duration of a stimulated button push is at 100 high and at 100 low.
I hope this helps
Good Luck on your project and let us know how it turns out
The problem is after connecting the ok and up button to the relays it's not functioning as what it should. It's works fine before connecting the second relay.
Anything I should consider?
After testing all the button I get 2.5V from the inner ring and ground for the outer ring but only the on off button is opposite. I'm using the relay to push the button one by one not two at the same time. I can get it as fast as 50ms high and low.
Can·somebody post the schematic or pic of the setting.
....having been a tech for Sprint for about 4 years, it seems it would be easier to just build a serial cable and access the handset through serial functions. All manufactures have them for programming and testing, modem dialing, all sorts of things.
This seems a bit more functional with a stamp. You could also access the headset port, and use the parallax text to speech to send voice maybe.
I don't know... just a few ideas from a newbie device hacker.
Could you post a drawing of how you hook up these relays on the output side of these relay
I know how to hook up the input side of it
In the data sheets it dose not show a test hook up
Thank You for any help that you can give with this
··Thanks for any·
Sam
Yeah the serial cable can interface with the phone, and make it dial out. A lot of phones communicate via TTL also. You would just have to look up the manufacturers specs on it to see.
http://forums.parallax.com/showthread.php?p=744931
http://forums.parallax.com/showthread.php?p=756456
Post Edit -- adding...· http://forums.parallax.com/showthread.php?p=761430
Point being: depending on what you want to do, instead of making some relay_contacts-to-buttons interface, you may get by with a cable.
Post Edited (PJ Allen) : 12/25/2008 11:03:01 PM GMT
I've solve the problem. The first·relay is spoilt. After replacing the relay now everything works fine. Now i can control all the function of the cellphone.
Thanks to all.
Merry X-mas to all.
Post Edited (azmax100) : 12/26/2008 6:20:44 AM GMT
