prop wont connect with computer
i have been working on getting an mp3 player to work, i had it working so·i disassmbled it from the·prop(it was unpowered) and decided to try my xbees, and holy Smile i got them working(im so proud of myself), so i decided i would go back to the mp3 player and i have it all hooked up right and had it powered, all leds on, then i played with it a little last night and couldnt get it to play, thought it was a coding thing so i went back and changed the code today when i got home, just hooked it up and i get a "scanned com port, no propellor found" or something like that, i had it working last night with the computer but not today, anyone know whats wrong
Based upon your description, you seem to move around a lot. Did you take precautions against ESD (electrostatic discharge) by grounding yourself before touching your frenetically charged body to it?
Just thinking out loud here.
1) Something wrong with the power source. A Propeller has to be powered to be found.
2) Something wrong with the comm port. There has to be communication between the Propeller Tool and the Propeller
·go check the USB device manager settings on that device as sometimes the darn thing WILL loose it!
By refusing to load! weird but wonderful,happened to me with a 2102 USB device!
when you install these things one must not have the usb device plugged as it will try to find the driver.
and it will work fine till NEXT time! "WELL! it worked last night"
Remove all copies from system"Add/remove"(the execute ones do this) and uninstall the driver!
reboot! and unplug the USB connector,then reinstall,once that is done,reboot and plug it in!
The problem is it tries to install twice at the same time! it works,but conflicts with the other part which did not install.
the first one loads the driver directly,the second tries to FIND it by scanning everything except looking to see if it is already in place
then cries
Merry Xmas to ALL!
Cheers Dennis
http://people.delphiforums.com/cocokiwi/Image/picture.jpg
