Why does start up take so long???
Hello,
Well I have 2 pules's going into the Propchip.
Now the PUB TimeingRelay runs fine and so does the PUB TVDisplay, but Pub ExicuteRelay will not start until about one minunte goes by. Why won't it start immediately like it is soppose to???
I thought that it had to do with useing the same variables (mes1,bmes2) so I made and set some varuaibles in PUB TimeingRelay just for PUB ExicuteRelay (mes3, mes4) , but it made no difference. I can't figure it out.
Any thoughts
Any thoughts
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
In fact, the interpreter takes 381 cycles of final overhead when the command is written in the form waitcnt(offset + cnt). This means the value of offset must always be at least 381 to avoid unexpectedly long delays.
Because of this, mes3 and mes4 should be at least 400. The time it is waiting for has already past when waitcnt starts.
www.tdswieter.com
Mes3, mes4 ect are all larger then 10_000_000. Which is why I couldn't figure out why it would wait so long before it would start. I finaly beat my head on the wall hard enough that I figured mabe that wasn't the problem.
What the problem was was the waitpeq command. I was waiting for the same pin to go high before before both the programs would continue past. So I ran the same pules to another pin and had one waitpeq wait for pin 7 to go high and then I had the second one wait for pin 5 to go high and it worked how it was soppose to.
I was under the impression that all the cogs had access to all the states of all the pins all at the same time. Why if I have two cogs waiting for the same pin to go high before continueing would only one ( the first one) sense that pins high state and continue while the second one waits for the frist program to stop and then wait's another minuet and then starts???
I attached the working program.
Any Ideas why it worked like that but not the other way?
I put a waitcnt of one second before starting the loop so that beforeon had time to initialze and it works like a charm
Thanks so much
