New To Propeller - Please Help Clarify XTAL Selection
Okay, I did the prerequisite google search and forum search and while there is plenty of information out there I would have to desiminate quite a bit just to get the answer I'm looking for. I'm not new to uChips and have worked with PICs for about 8 years now so I'm not unfamiliar with the concepts, I'm just confused about how the Propeller treats the external oscillator and the differences between external and internal oscillators (as it pertains to the propeller application). Specifically, I'm confused about why the specs say that the propeller will run up to 50Mhz yet it also states that the external oscillator can be any where between 5-8MHz. If the PLL multiplier is 16x (which I think I read somewhere, but that may be off too) then even at 5MHz you are over the 50MHz threshold (if using 16x PLL). I didn't read too much into the details of the PLL register, and maybe I should (I guess I'm used to just setting a FUSE for HS, XT, or RC and being done with it), but I am hoping for something more straightforward in my hardware design than relying on a software switch.
Here is what I am looking for - if I used a 5MHz crystal what is the highest PLL setting I can use and therefore the highest clockspeed the Propeller will run at? And secondarily, what how many MIPS does the Propeller execute at that setting?
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
