Wheel Enconder Kit (#27972)
Hi:
Regarding the encoders, are these the most accurate you have pertaining to resolution (wheel position)? Is item (#28107) more accurate? What· about incorporating a higher resolution enconder that may be purchased elswhere? I need to have distance dead-on for my application.
any help is appreciated.
Thank you!
Thank you!
Dave
Dave Andreae
Parallax Tech Support·
Please advise and Thank you!
please advise and thanks again!
I hadn't thought of a mouse! Are you using one? I am rolling on smooth, shiny concrete. I am ceratinly not moving any faster than one would on their desktop/mousepad. How would I go about tieing a mouse(serial/usb) into the Parallax system and do you or anyone have any code to do this?
Thank You!
As for the mouse, I mentioned it somewhere in another thread where the same thing is desired, but I don't remember the title. Anyway, the gist was that you simply hook it up to the propeller, and use the mouse movements as distance traveled, and you have a simple and cheap distance encoder. With the right lens, you might even be able to move the mouse off the ground and up into the air.
