basic stamp 2e — Parallax Forums
basic stamp 2e
alexeenalexeen Posts: 6
edited 2008-12-17 19:02 in BASIC Stamp
how do i clear out the memory 0f basic stamp2e??
    edited 2008-12-14 17:16
    You don't have to clear out the memory. If you want to install a new program, just use the Stamp Editor to download the new one. It will replace the previous program in the Stamp.
  • SRLMSRLM Posts: 5,045
    edited 2008-12-14 19:36
    All the scram and ram gets set to zero when a the reset button is pushed, or a new program is downloaded. The EEPROM stays the same, until you overwrite it with either a new program or the WRITE command.
    Hello,
    You can disable the current program, setting all I/O pins to input by downloading a program with nothing more than an END statement. I hope this helps. Take care.
    Parallax Engineering
