Combining Toddlers...? — Parallax Forums
passingofamericapassingofamerica Posts: 3
edited 2008-12-18 19:06 in Robotics
Inspired by Star Wars' AT-AT, using 'mechano' my robotics class partner and I have been trying to combine two toddlers. We were successful in physically combining them, but are now stuck on making the robots react to IR sensors in sync.
Our first attempt was to simply 'piggyback' the signal from the IR receivers in the front bot and have the wires plug in to the pins, Vss and Vdd ports in the back bot. While the front IRs were working correctly, the rear bot did not appear to receive the signal.
We then tried to use two individual IR receivers on each left and right (one for the back, and one for the front bot) however, that plan seems to have failed as well.
We are testing the IR signals using two IR Test Programs on individual computers (one for each bot) and we cannot seem to make this work. We are confident our wiring is correct (works well with LEDs), however, we are still stuck.
Any thoughts/suggestions?
Post Edited (passingofamerica) : 12/15/2008 3:02:30 PM GMT
    edited 2008-12-14 06:09
    How about a schematic showing how you have the two Bots connected?
  • GWJaxGWJax Posts: 267
    edited 2008-12-14 06:28
    Also post the code as well so we can get a full picture of what your doing and a Picture of your bot may help as well.
    Jax
    If a robot has a screw then it must be romoved and hacked into..
  • UghaUgha Posts: 543
    edited 2008-12-14 12:55
    I've had good success with using one stamp as a master and the other as a slave... the master tells the slave to do an IR scan
    via SEROUT and then uses SERIN to wait for the result.
    Slave receives the message (It always sits waiting for instructions while its not actually doing anything) and then does the IR
    scan, sending the IR results back to the master via serial.
    Like the others, I'd be able to help you more by seeing how you have things wired up and coded.
    edited 2008-12-15 06:59
    I'll be interested to learn how your FrankenToddler walks, or more specifically, how it turns. That tilt/stride mechanism seems to be optimized for a biped that rotates about its own axis, sort of a differential drive for walkers. It might struggle with four legs on the ground, or you may get a pleasant surprise and it may work great. If you get a chance, please post a Youtube video.
    edited 2008-12-16 02:40
    If you attach a swivel joint between the body of the legs you can get it to make a good gant if programmed right.
    Jax
  • Ken GraceyKen Gracey Posts: 7,407
    edited 2008-12-16 03:30
    I've programmed a set of Toddlers to dance. These guys are linked via our RF modules:
    http://www.parallax.com/Resources/ApplicationsContests/Robotics/ToddlerTroupe/tabid/504/Default.aspx
    Download the video to see what it's all about. Here's a photo of them:
    500 x 375 - 57K
    edited 2008-12-16 05:42
    Ken, that's an awesome project! The web page is
    well put together with complete information and very
    useful. But how did all those Toddlers become
    black and blue? What's the story behind that?
    humanoido
    edited 2008-12-16 05:53
    Hey humanoido,
    The blue is the square dance caller, and has the RF transmitter. The black Toddlers are all receivers, or the square dance participants. Well, it's not really a square dance but a "hokey pokey" kind of party.
    They're individually powder-coated. I tried that instead of anodization once to compare the finish. The quality of powder coating was fantastic, though it certainly introduces more issues relative to tolerance than anodizing.
  • passingofamericapassingofamerica Posts: 3
    edited 2008-12-17 14:23
    ···· Thanks for the responses so far...
    Okay I have some pictures and schematics...
    Side View
    Close Up
    Wiring On Front Bot
    Wiring On Back Bot
    Schematics ...
    Hopefully all of this is helpful.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    'Testing only right IRs...
    ' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
    rEmitter CON 10
    rInput VAR IN11
    ' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
    rDetector VAR Bit ' detector output values.
    ' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
    OUTPUT rEmitter
    ' -----[noparse][[/noparse] Main Code ]-------------------------------------------------------
    DO
      FREQOUT rEmitter, 1, 38500
      rDetector = rInput
      DEBUG " Right= ", BIN1 rDetector
      PAUSE 20
    LOOP
    This is all we have for code. Just wanted to make sure the IRs worked between both bots before we dove in. Our plan was to use the same program in both bots, have them run at the same time and hopefully react the same.
    P.S.
    ····· The hokey bots are pretty cool. [noparse]:)[/noparse] Kinda creepy though....
    Post Edited (passingofamerica) : 12/17/2008 2:29:53 PM GMT
    481 x 462 - 87K
    545 x 645 - 93K
    752 x 500 - 107K
    752 x 500 - 110K
    652 x 364 - 13K
    edited 2008-12-18 03:10
    here, I made some changes to your code that should work better for you.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    rDetector VAR Byte ' detector output values.
    rOutput VAR Byte
    rInput VAR Byte
    rEmitter CON 10
    rInput = IN11
    OUTPUT rEmitter
    DO
    rDetector = 0
    rOutput.LOWBIT = ~rInput
    rDetector = rOutput
    PAUSE 20
    LOOP
    Jax
    UPDATE::
    ············ Because we only have until tommorow before our school's christmas holiday we decided to take a sure (but messy) route. We decided to use the toddlers pre-made IR pins for the set of IRs on the lead bot, while the board of the lead bot works as a sort of holding place for the back bot's·IRs.
    Schems:
    This works, okay, however, ...four fidgety IRs isn't·as precise as I wish
    P.S.
    ·· Can someone explain the improvements Jax added?
    900 x 364 - 17K
