LED example in "What is a microcontroller" problems
Here's my problem.· It looks like that somehow pin 15 on my basic stamp does not function properly.· Is there a method that allows the OUTH and DIRH commands without using pins 8-15 and instead use 7-14 for example?
Thanks!
Thanks!
I've done a simple code that turns pin15 high and plug in an led, and it does not light. Same went with a buzzer I attached (and it was a simple circuit with the gound attached)...so i'm fairly confident it's burnt out.
