Problems with USB and StampPlot Lite
Hello,· I currently am following the instructions in the "What is a microprocessor" guide exactly as described and am having problems getting my stamp to interface with the Stamp Pro Lite program.· After selecting the cooresponding COM port in the program, I get the error "the selected COM port is not available."· I've uninstalled the program, reinstalled the program, tried chaning ports and haven't had any luck.· Any ideas to help?
I'm kind of new at this however i have done the stamp plot program and if you have the debug window up from the stamp editor then the stamp plot cant access that port. Two different programs can't access the same port. make sure you have the debug window closed from the stamp editor before you try and connect with stamp plot
