DS1620 Temperature sensor and Basic Stamp (accuracy)
I am using the Basic Stamp 2 with the DS1620 temperature chip
code.
I need to read in Celcius and about 0.5 accuracy.
The example code is working at 1.0 accuracy , do you know
if other customers have more accuracy ?
thanks , Joe
code.
thanks , Joe
Here are a couple of threads that might help.
http://forums.parallax.com/showthread.php?p=606317
http://forums.parallax.com/showthread.php?p=608042
In High Resolution mode, the resolution is:
0.0625°·C
0.1125°·F
Beau Schwabe
IC Layout Engineer
www.emesys.com/OL2d1620.htm
Tracy Allen
www.emesystems.com
Tracy, I have load your code and at the beginning it doesn't work.
But after I deleted a code line the DS1620 worked.
Your code is very good and I am afraid that your code
line (please see attac.) is there for a reason.
What do you think ?
Thanks, Mark
I'm not sure what might be wrong with the original code. The $AC command requests the status byte, and bit 7 is of that byte is the busy(0)/done(1) flag. Dallas Semi did make some revisions in the chip, but I don't recall seeing anything about that flag. Hmmm.
Tracy Allen
www.emesystems.com
