A/D Help
Need some help!
I have a Propeller demo board w/LTC1298.
I·went to the Propeller Exchange and located the LTC1298 folder.
I connected the LTC1298 as per the diagram in the CD_LTC1298 program file within the main folder.
I do not see, how this particular program displays and output of the A/D
I've tried the CD_Test_LTC1298 and that displays, what looks like binary reading for two channels.
I want to be able to collect data using the LTC1298 with a Propeller and send the data in "volts" out a serial port.
Can anyone help with this???
tom
tom
Unless it's a "pain" using the TV screen, I suggest you modify the test program so that you're displaying the exact text strings that you want to see go out a serial port. It's then trivial to add the Simple_Serial.spin I/O driver to the test program and output the text string out a serial port as well as the screen. If you want, you can leave the TV display code there and just not connect the TV.
Most of the code in the test program is there just to set up the TV driver and you can ignore it. The main part you need to be concerned about is what's labelled as the "Main Program Loop". Do take a look at the Simple_Serial object and the example that comes with it.
The ADC and the current display routine shows the output of the two channels of the LTC1298 in binary form and in decimal form and the data is provided as integers ranging from 0 to 4095, always positive and representing the voltage <value> * Vref / 4096. You'll need to decide how you want your voltage displayed. Is there an offset? How many decimal places do you want to display? Is there a multiplicative scale factor? There are easy ways to do all this using integer arithmetic or you can use the Propeller's Floating Point Package to do this (have a look at it).
OK, so I want to display the voltage collected as volts, there is no offest and would like to display 0 to 3 volts. How do would I do this? Can you·help to better understand what has to be done?
thanks in advance for your help
Tom
Temp := adc.GetADC(0)
and
Temp := adc.GetADC(1)
To convert the readings (ranging from 0 to 4096) to voltage, the scale needs to be adjusted. 4096 corresponds to 5V for the LTC1298. Say we assume 3 decimal places, so 5000 milliVolts corresponds to a reading of 4096. If you use the following line, you get a display in milliVolts:
Temp := adc.GetADC(0) * 5000 / 4096
If you want your display to be in Volts with the embedded decimal point, the Num.ToStr result will have to be modified. If a milliVolt display is adequate, the above formula will do. Note that the voltage range is 0-5V because the LTC1298 runs off 5V and uses the supply voltage as the reference voltage for the conversion.
Thanks I got the program to display both values channels in decimal form on the TV screen displaying millivolts.
For now I wiil experiment with Millivolts rather than volts.
Ok, So finally I want to send the two readings out a pin desginated as a serial port output using Simple_serial.spin or Duplex_Serial.spin. How do I assign a single pin as a serial port? How do I incorporate that into the program? And what else do I need to consider?
Once again thats for your kind help!
Tom
I 'am confused and do not understand your last response below!
[noparse][[/noparse] I think you can use -1 for the receive pin # when you initialize it if you're not going to use the receive side.]
I'am using the Propeller Demo board, with P0 and P1 commuicating with the LTC1298.
I want to use a single pin such as P2 for the serial output to send voltage reading out the serial port.
I only want to send voltage readings one-way out of the Propeller Demo board to remote serial display.
So, using the modified CD_TEST_LTC129 program, how do I declare pin P2 as a serial output and how do I send the serial info out the serial port pin P2??
tom
So how do I assign P3 as an output on the Propeller Demo board, then how can I send serial millivolt reading out the serial port at P3 using "FullDuplexSerial"?
any help would be greatly appreicated!
thanks
Tom
and am having trouble getting it to work.
Set the din pin to pin+3 and set it to input
I set the dataio pin to out. I compiles but I get nothing.
Can you see where I am going wrong. I am sure it something simple I am overlooking.
Thanks guys
PUB GetADC( chan ) : adcr | ADC_Val
if (chan == 0)
ADC_Val := convert(0)
if (chan == 1)
ADC_Val := convert(1)
return ADC_Val
PRI init( cs_, clk_, dataio_,Din_ )
cs := cs_
clk := clk_
dataio := dataio_
Din := Din_
dira[noparse][[/noparse]Din] := 0
dira[noparse][[/noparse]clk] := 1 ' set clk pin to output
outa[noparse][[/noparse]clk] := 0 ' Set clk to Low
dira[noparse][[/noparse]cs] := 1 ' set Chip Select to output
outa[noparse][[/noparse]cs] := 1 ' set Chip Select High
PRI convert( ad_chan ) : datar_val
if (ad_chan == 0)
ADC := CH0
if (ad_chan == 1)
ADC := CH1
dira[noparse][[/noparse]dataio] := 1 ' Set Din/Dout to output
outa[noparse][[/noparse]dataio] := 0 ' Set Din (output) Low
datar := write(ADC) ' write MUX Address to start conversion for SDC channel (delay needed???)
return datar
PRI write( cmd ) : datar_val | i
datar := 0 ' Clear the data storage LONG
outa[noparse][[/noparse]cs] := 0 ' set Chip Select Low
writeByte( cmd ) ' Write the command to start conversion for X port
'dira[noparse][[/noparse]dataio] := 0 ' set data pin to input
delay_us(2) ' Clock delay
' Ok now get the Conversion for this channel
repeat i from 12 to 0 ' read 12 bits 11-0 for MSB
outa[noparse][[/noparse]clk] := 0 ' toggle clk pin High
' delay_us(2) ' Clock delay
if ina[noparse][[/noparse]Din] == 1
datar |= |< i ' set bit i HIGH
else
datar &= !|< i ' set bit i LOW
outa[noparse][[/noparse]clk] := 1 ' toggle clk pin Low
return datar
PRI writeByte( cmd ) | i
repeat i from 0 to 3 ' LTC1298 has 1 start bit and 3 data bits
outa[noparse][[/noparse]dataio] := cmd ' send LSB bit
outa[noparse][[/noparse]clk] := 1 ' toggle clk pin High, Chip reads on rising edge.
outa[noparse][[/noparse]clk] := 0 ' toggle clk pin Low
cmd >>= 1 ' shift to next bit
PRI delay_us( period )
' CLK HIGH/LOW time = 2µS MIN
waitcnt((clkfreq / 100000 * period) + cnt) ' Wait for designated time
I will be trying hi speed opto couplers in the 4 lines next.
thanks
Jim
