PINK worked, now doesn't; Ethernet light blinking
I hooked up my PINK today to start working with it.· It's one I bought a year or so ago and haven't worked with it.
Everything worked fine. I had a great connection and was working with the variables.· Without changing anything, now the network cable port light is blinking and communication between the PINK and my network no longer works.· I cycled the power on the PINK and the router it is connected to but no luck.
Any idea what might be causing this?
Dave
Dave
It appears to me that it is trying to tell me something is wrong.
Dave
Does anyone know if Parallax makes the firmware available so that I can reprogram my PINK or am I outta luck?
Has anyone else experienced this problem?
I·am going to·work the new module the same way·as the last one because I would really like to have it work, but I think I will take it one step at a time.· If the module gets messed up this time, maybe it will expose an error in the firmware that Parallax can correct.
Hopefully, this information helps anyone in the future that may have the same issue.
Parallax Engineering
