STAMP, Xbee & VB.NET Help.
Hello everyone,
Can anyone help me find the missing link? My code on the STAMP side and VB side works perfectly while my STAMP is connected to the PC via the USB cable. Once I put the Xbee modules in between (one connected to the USB and one mounted to the STAMP) i cannot get the Xbee module connected to the PC(VB App.) to send the Variable from VB to the Xbee module mounted on the STAMP. I know the Xbee modules can communicate to each other because if I close my VB App. and open up a terminal window, I can send data from the terminal to the STAMP. My guess is that it's some kind of Syntax issue on the VB side with the Xbee. I have done research on this issue for the past 4 days to no avail. Attached is a little bit of the VB code and STAMP code. Any help would be greatly appreciated. Thank you!
