Installation of Servos
Hi everyone, I searched the propreller section of the forus and couldnt find anything on this.· Also, I have checked the docs.· I am working on an a robotic vehicle project and my proto board USB just came in.· I need to control several servos, and would like to use the built in servo circuit, but I am a little confused.· I soldered the headers in and have a shorting block to put on the Vservo header, but I don't know how to connect the signal line to a pin on the propeller.· Is it already wired or do I need to run one myself?· Perhaps I'm just being obtuse [noparse]:p[/noparse]
Thanks in advance.
Thanks in advance.
I'd suggest to Parallax that they make this more clear in the documentation. I struggled with it quite a while too. I think I eventually found it somewhere, but it should be in the instructions for soldering together the Proto Board Accessory Kit. Of course now that I look closely in the photograph, I see that there's a nice little line there on the silk screening indicating the connection. I guess my near vision isn't what it used to be.
Warning: I'm working from a regular protoboard, not a Protoboard USB. You might want to verify that things are the same on the USB version before soldering.
Post Edited (sylvie369) : 12/10/2008 3:55:52 PM GMT
