IR Record and Playback
william chan
Hi guys,
The 38Khz carrier using CTRA works perfectly.
But now the record and playback in SPIN only works for about 20% of equipments I tested.
For example, it works with Panasonic remotes, but not Philips or LG remotes.
Could it be SPIN is too slow to make accurate sampling at 80Mhz?
The record_ir() code I copied from the IR_Kit in the OBEX.
I wrote the playback_ir code(), but it seems difficult to accurately match the time per loop for record and playback.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 12/10/2008 1:31:02 AM GMT
CON
_maxbuff = 500 'number of marks and spaces max
_quiet = 10000 'ir completely quiet
VAR
long buff[noparse][[/noparse]_maxbuff]
long samples
pub record_ir | iron, iroff
dira[noparse][[/noparse]ird1_pin]~ 'make irdetector pin input
samples~
repeat while ina[noparse][[/noparse]ird1_pin]==1 'wait any mark
repeat
iron~
repeat while ina[noparse][[/noparse]ird1_pin]==0 'time mark
iron++
if iron > 10000 'this just balances mark/space counts
return
buff[noparse][[/noparse]samples++]:=iron
iroff~
repeat while ina[noparse][[/noparse]ird1_pin]==1 'time space
iroff++
if iroff>_quiet 'end of train
buff[noparse][[/noparse]samples++]:=iroff 'save last
return
if samples => _maxbuff-2
samples -= 2 'don't overfill the buffer
PUB playback_ir | i, count
i~
repeat
if i => samples ' done?
quit
count := buff[noparse][[/noparse]i++]
dira[noparse][[/noparse]irled_pin]~~ ' Make pin output to send IR signal
repeat while count>0 ' mark
count--
if count > 10000 ' this just balances time per loop
dira[noparse][[/noparse]irled_pin]~ ' Make pin input to pause IR signal
repeat while count>0 ' space
count--
www.fd.com.my
www.mercedes.com.my
At the top of the file?
I didn't post the clock and freq code b'cos I don't want too much clutter on the example code.
www.fd.com.my
www.mercedes.com.my
noPulse := false temp := cnt repeat until ina[noparse][[/noparse]ird1_pin] <> 0 if (waitTime := cnt - temp) > timeout noPulse := true quit if noPulse ' no pulse was detected else tooLong := false temp := cnt repeat until ina[noparse][[/noparse]ird1_pin] == 0 if (pulseWidth := cnt - temp) > timeout tooLong := true quit if tooLong ' width of pulse > timeout else ' we have a valid pulse, save it and the off time prior to the pulse to the arrayNote that you'd have two values for each pulse, the off time prior to each pulse and the on time of the pulse.
You'd obviously ignore the first off time since its unrelated to the pulse train. To play it back, you'd set the
DIRA bit to 1 and do a WAITCNT(value[noparse][[/noparse] x ] + cnt) where value[noparse][[/noparse] x ] is the first time value, then toggle the
DIRA bit, increment x, and do another WAITCNT repeating the whole sequence for each recorded time value.
At the end of the pulse train, you'd just set the DIRA bit to 0 turning off the IR pulses.
Post Edited (Mike Green) : 12/10/2008 6:00:54 AM GMT
I don't quite understand why your code is totally different from mine.
Would your code's timing be more accurate?
www.fd.com.my
www.mercedes.com.my
But there is a small problem.
Sometimes when we WAITCNT(buff[noparse][[/noparse] x ] + cnt) during playback, the value of buff[noparse][[/noparse]x] may be too small, causing the cog to wait forever.
If we set a minimum to the value of buff[noparse][[/noparse]x], it will cause the pulse train to become unfaithful.
So how now?
www.fd.com.my
www.mercedes.com.my
2) You're correct about there being a minimum WAITCNT increment. It's roughly 400. You might set 1000 as a minimum. It's only about 12us, less than a half cycle of the 38KHz carrier. You shouldn't see delays this short.
