I need a suggestion for a MOSFET(?) that controls a siren
Hi everyone,
I've been asked if I can use a Propeller to monitor the doors and windows of a building and sound a siren if anyone intrudes. The siren is already in place and I have no documentation for it except what I've gained by testing it.
At 3 volts, it uses less than 0.1 amps and barely peeps.
At 5 volts, it uses about 0.2 amps and makes a decent amount of noise.
At 10 volts, it uses about 0.3 amps and knocks my socks off.
I'm guessing some kind of MOSFET would do the trick, but I've never used one and I don't know what sort of criteria to search for on Digikey's spec search.
I have one of these ixdev.ixys.com/DataSheet/99444.pdf sitting around, but I'm not sure it would be right for the job.
Any suggestions on how to approach this problem will be greatly appreciated.
Mark
Mark
'Just a few PropSTICK Kit bare PCBs left!
Awesome, man! Your suggestion looks great.
Thanks!
Mark
Tie the + of the siren to your 10V power and the - of the siren to the drain of the FET. Then tie the source on the Fet to a common ground with the prop's power.
thanks for the tip on using a 1K resistor to buffer the output of the Propeller pin. I often forget: even if the component doesn't short out the pin, something else I do probably will short it sooner or later.
cheers,
Mark
