A/D Propeller Question
I have the Propeller Demo board hooked up with an LTC1298 A/D chip.
I ran the CD_1298.spin program from the Propeller Exchange but see no output on the screen.
Question: Is this program supposed to display voltages on the screen?
··············Does this program have a output to see voltages from the A/D?
thanks for any help!
Tom
Tom
as you can see inside the CD_Test_LCT1298.SPIN-file this file uses
the followong objects
OBJ
tv : "TV"
gr : "CD_Graphics"
Num : "CD_Numbers"
adc : "CD_LTC1298"
This means you should see something on a TV.
As your question is very basic I recommend to check the following things:
did you compile and transfer the file "CD_Test_LTC1298.spin" ?
Do the IO-pins on the demoboard connected to the TV-DAC fit with the definition inside
the SPINfile ?
here I comment on the documentation of the LTC-1298-object
there is no documentation at all ! The only documentation is the chip-number
this is "extensivly too much" documentation
Does their exist a special reason why the documentation and adjusting of the TV-object is so cryptic ?
best regards
Stefan
I loaded the CD_LTC1298.spin and compiled the -- not the CD_Test_LTC1298.spin.
Looking at the CD_LTC1298.spin - iam not sure how that program displays its output.
Iam looking for help to be able to output a serial data stream based on the output.
How would I do that?
thanks
Tom
