Strange noise on motors — Parallax Forums
ArielAriel Posts: 27
edited 2008-12-11 17:25 in BASIC Stamp
Hello again.
I'm having a very bad experience with my new motors. They are Futaba standard servos. I don't really know what happened to them. I'm posting two videos so the more experienced people can see what is the problem and pleeeease help me out with this.
The motors are getting stuck all the time and do a very strange and creepy sound
Plus, can somebody give me a code example to control a standard servo? i saw the code on the servo's technical page. but i cannot understand the logic. I programed a servo in the exact way that says in the technical page with different numbers but i cannot understand the big idea.
The videos are at youtube.com
MOV00387.MPG <-- showing the noise i'm talking about.
MOV00388.MPG <-- I don't know what happened to this motor. I just gave a simple instruction to move to a certain position but this happened.
    edited 2008-12-09 21:06
    Well, first of all, the Servo control signal is:
    A pulse, from one millisecond to two milliseconds in width (depending on desired output position) repeated every 20 milliseconds to 50 milliseconds. Period.
    Don't try to repeat the pulse more often, that's outside the specification and simply won't work.
    Now, the 'plain vanilla' BS2 "PULSOUT" command is in 2 uSec units. So, to get a 1 millisecond pulse, you give it 500 ( 500 * 2 uS == 1 mSec). To get a 2 millisecond pulse you give it 1000. And to make it 'stop' you send it a 'center' position command -- which is a pulse of 1.5 mSec, or 750.
    Now, you still need to 'refresh' the commanded position every 20 milliseconds, or the servo won't "hold" position.
    So, what 'flavor' BS2 do you have, and what does your 'control' code look like?
  • LilDiLilDi Posts: 229
    edited 2008-12-09 22:54
    It looks like and sounds like the servo is under powered. 6 volts is optimal for the power supply.
    http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/stdservo.pdf
    edited 2008-12-11 17:09
    I'm guessing these are damaged servos from the robot arm project you posted seperately. That project is a servo killer with those long joints. Can't tell exactly what is wrong, but they are obviously damaged. Could be mechanical and/or electronic damage. MOV00387 looks to be a continuous rotation servo, my guess is that the internal gears are damaged since you need to thump it every now & then to keep it going. MOV00388 looks like the range is limited to a small portion of what it originally was, and it has very low stall torque. Again, probably gear damage.
    The truth is that these little servos are fragile and the long arm you built has very high load requirements. The internal gears are nylon and the tiny gear teeth get damaged easily. Servos are intended for low loads and fast response, you need just the opposite. The old saying about "cheap, fast & accurate, pick two" needs to be amended to read "cheap, fast, accurate & strong, pick two".
    There are "high torque" servos out there with metal gears (cheaper servos use nylon) that can cost $100 and up. They would last longer in your arm application, but IMHO I doubt if you will get great accuracy from them. They still use fairly cheap potentiometers for position sensing, and their repeatability is within a few degrees. That's fine for a servo horn arm length of an inch or less, but your joints each appear to be 12" or longer. The longer the arm, the more the error will likely be. Also affecting your accuracy: your long joints will flex, and your drive belts will stretch a bit under load.
    If you want to continue using servos, I would recommend scaling your arm down to one-third of its current size or less. Your results will be better and the servos will last longer.
    Based on your other thread, I'm betting you've got series "pullup" resistors on the servo power leads. Get rid of them.
