How to use the Counter in SPIN to create a carrier?
Let's say I need to create a carrier for an IR led at 38Khz.
I believe using a loop in SPIN is too slow for 38Khz. ( Assembly would use up another cog )
Can I use a cog's CTRA or CTRB in SPIN to do this?
Any example codes to set up the counters in SPIN or to start or pause the carrier would be most appreciated.
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Once you've been able to get a steady 38KHz output, you can modulate it by alternating the same pin (via OUTA) between 0 and 1. When 0, you will see the 38KHz output; when 1, a straight high. This is because the output from the counter is ORed with OUTA. This also implies that you will want to use current-sinking to drive your IRED: i.e. tie the anode high through a current-limiting resistor, and connect the cathode to the pin. This way, when the output is high, the IRED is off.
'Just a few PropSTICK Kit bare PCBs left!
You guys are genius!
Why can't I set
frqa := 0 and
outa[noparse][[/noparse]pin] := 0
to pause (modulate) the 38Khz carrier? Too slow?
My circuit is already connected to a bipolar NPN transistor which sinks the current from the IRED to ground, so I can't have the
output pin high when idle.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 12/9/2008 6:15:22 AM GMT
You'd do FRQA~ followed by PHSA~ to stop the 38KHz carrier. You'll have to set them both to the proper values to start the carrier again. This would certainly be fast enough, a fraction of a cycle of the carrier.
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
But using 3.3v to power the IRED would heavily load the 100mA 3.3v regulator.
If we use a NPN transistor, the power source can be tapped from 3.3v, 5v or 12v supplies. More choices.
www.fd.com.my
www.mercedes.com.my
You could use a separate 3.3V regulator for the IRED and still drive it with a PNP. Its forward voltage is only about 1.2V, so there's no necessity to sink it from a 5V or greater supply — as there would be for, say, a blue LED with a much higher forward voltage.
ctra[noparse][[/noparse]30..26] := %00100 'Configure Counter A to NCO ctra[noparse][[/noparse]8..0] := PIN 'Set Counter A Output to PIN frqa := 2_040_109 '= (38kHz)*(2^32)/(clkfreq)
this is assuming clkfreq is 80 MHz
