OEM BS2 resonators
Hello All
Is it possible to·parallel the ceramic resonators or Xtals on the OEMBS2s. I don't want to change the clock speed,I just need·two OEMBS2s "PIC16C57C" to run in sync. with each other.
I looked for some info on this,I couldn't come up with anything?
___Thanks for any info_______$WMc%__________Merry Xmas__
The Truth is out there
I think that the attached would have the two OEM PICs running from the same clock.
Post Edit -- Here's the link to the PIC datasheet (pdf) from Microchip
Post Edited (PJ Allen) : 12/9/2008 1:38:13 AM GMT
You are the Man!!!!
Exactly what I was looking for
____________$WMc%______Merry Xmas
Post Edited ($WMc%) : 12/18/2008 2:23:55 AM GMT
Parallax Engineering
Also, I get a ding because the PIC's input buffer is an inverter (see datasheet Figure 4-1.)· So,·PIC #1's·OSCOUT fed to PIC #2's OSCIN would result in the two clocks being 180deg out of phase (another inversion in PIC #2.)
Post Edit -- dwg attached.
Post Edited (PJ Allen) : 12/9/2008 11:53:32 PM GMT
In many cases your suggestion would work fine...But on some systems very balanced loading is required and without it, things don't work right. This question came up not too long ago regarding the SX and that is a perfect example of where you have to following the proper load capacitance, feedback resistance and drive. Take care.
I would like to think You both for the help and info.
I know that the "wire / trace" length is important,But I would still like to experiment with this.
I'll try the Ext. Clock 1st
______________$WMc%_____________Merry Xmas
I know of no other forums that are this helpful and informative(Thanks Parallax)
Post Edited ($WMc%) : 12/12/2008 8:51:13 AM GMT
Thanks for the added info. I started out in RF back in the day. It still amazes Me as to what a ground loop can do. And, induced noise with such little current!!. But it's this kind of experimenting that led to things like terminating resistors,Grounding a shield on one end only, twisted pair ,etc. Sometimes You just feel like playing with things to see what happens?
Thanks again________________$WMc%___________________Merry Xmas
