Boe-Bot Position Tracking
Using the defined source code for avoiding objects is there a a straight forward approach to following the movement and be able to have it back track if the user pressed a button for example?
Thanks.
Thanks.
Having said that, you COULD write duration values into the eeprom while it's running, and then 'rewind' those duration values to 'back-track'. But it's still not going to be very exact.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/position/List/1/ProductID/80/Default.aspx?SortField=ProductName,ProductName
