unexpectedly long pwm pulse lengths from r/c receiver
A PWM signal from a standard R/C receiver is connected to a Propeller pin with a 1k resistor. Sometimes my waitpeq/waitpne loop measures pulses that are roughly 3000 usecs long, roughly twice the expected length. Any ideas what is causing this? The signal looks normal on my oscope. The attached sample code reproduced the issue. Any help with this will be greatly appreciated!
The output looks something like this:
pwm test
2996
2995
2996
3010
3011
2996
2995
2998
3001
3007
3011
3008
3005
3007
2996
2991
2960
8342
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
pwm_in_pin = 11
dbg_tx_pin = 17
dbg_baud = 19_200
obj
dbg : "Simple_Serial"
pub run | t
dbg.start ( -1, dbg_tx_pin, dbg_baud )
dbg.str ( string ( "pwm test" ) )
dbg.tx ( 13 )
dbg.tx ( 10 )
dira [noparse][[/noparse] pwm_in_pin ]~
repeat
waitpne ( 0, |< pwm_in_pin, 0 )
t := cnt
waitpeq ( 0, |< pwm_in_pin, 0 )
t := ||( cnt - t ) / ( clkfreq / 1_000_000 ) 'convert to usecs
if t > 2000
dbg.dec ( t )
dbg.tx ( 13 )
dbg.tx ( 10 )
pwm test
2996
2995
2996
3010
3011
2996
2995
2998
3001
3007
3011
3008
3005
3007
2996
2991
2960
8342
spin
623B
let's ignore that for now...
am I correct in saying that waitpne and waitpeq don't detect rising edge and falling edge, but rather just a high or low level?
does adding one line before the repeat, as so:
... repeat waitpeq (0, |< pwm_in_pin, 0) <----- here waitpne (0, |< pwm_in_pin, 0) t := cnt waitpeq (0, |< pwm_in_pin, 0) ...fix the problem?
repeat waitpeq ( 0, |< pwm_in_pin, 0 ) waitpne ( 0, |< pwm_in_pin, 0 ) t := cnt waitpeq ( 0, |< pwm_in_pin, 0 ) t2 := cnt t := ||( t2 - t ) / constant( clkfreq / 1_000_000 ) 'convert to usecs if t > 2000 dbg.dec ( t ) dbg.tx ( 13 ) dbg.tx ( 10 )That way you're not only waiting for the rising edge of the signal, but you're also caching the counter value as quickly as possible before doing the math on it.· I'm not sure what order SPIN evaluates things in, but if it were to compute the divisor first, that divide would take a significant amount of time.· Adding constant() to it makes it evaluate at compile time, speeding up the code even more.
Since the debug code is 'outside' the timing loop, it shouldn't really be a problem, though it will mean that you don't get readings as often as you should.
If you can spare a cog, I'd suggest using the RCInput object found here:
http://forums.parallax.com/showthread.php?p=690465
It works well, and can easily be modified to handle fewer inputs with higher precision.· There's also one in the standard libs that ship with the Prop, but it requires sequential inputs, where the above object does not.
Jason
