New to the Propeller
Capdiamont
I finally got a non usb propeller protoboard with last week's sale. I also got the accessory kit. Plan is to eventually put it in a old blueberry imac. One problem is the site I've seen the mod I want to do for the pin outs, is having problems(MacMod). Thinking of making it my rs485 control/logging brain, I have the parallax usb stick interface, and the wiznet ethernet interface. The rest of the home network would be using SX's. That is the plan.
Since it won't show up till Tuesday, I've gotten the parts together for a programming interface, via rs-232, and been reading through tricks/traps, spin examples, and the manual.... wondering what did I get myself into.
I'm guessing by your avatar/msg count that you've jumped over with some BASIC stamp experience.
You'll have a good time with the Propeller. [noparse]:)[/noparse] Have a glance at the Cookbook (below). It will give you some
more ideas for your Protoboard.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
I actually received it on Monday, but wasn't allowed to play with it.
Tuesday started assembling rs-232 programmer, forgot to buy the 3906 transistor. Put together the accessory kit except the servo part. Don't know if I'll do servo's on this one. Most likely, move it to a SX board.
Today, haven't time to finish the programmer. Should of gotten the prop clip.
I also download, but forgot that I did so, the cookbook. Tried to download as much as possible to try and figure things out. I have one bs2, that I haven't dedicated to anything, just seems a bit expensive to do so.
One sx dedicated at the local fair, for the lighthouse flasher.
Wasn't able to view the forums for a few days due to some internet error, and ended up finding my topic on page 3!
that's the story around it
where's your first propeller-related question ?
the forum is keen on answering propeller-related questions
We are waiting ! Don't test our patience too much
best regards
Stefan
using www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
for usb to rs232/9pin Parallax usb to serial adapter. Works great with other stuff, phone systems, VM etc.
Waiting till tomorrow to post more, for fresh eyes(mine)
I'm using a fresh set of 4 d cell batteries in series, voltage out is 6.44v, center pin positive, led on propeller board does come on when turned on. I turn it on, before attempting to program.
I've probability wired the programming adapter wrong, but I don't see any errors. I've checked it vs circuit diagram. I've checked for shorted traces, visually, and ohm meter. I've checked for cold joints. I did change the order so the output to the propeller board matches the regular programming adapters. I do have 3.3v going where it is supposed to go.
The usb adapter power led is on, activity led will do a quick blip when I try a identify hardware. comm 1 is the adapter.
it is the Parallax USB to 232 rev b.
the cap is a .01uf polyester-film.
update, previous schematic was failing on the netlist checker
Post Edited (Capdiamont) : 12/13/2008 5:18:57 AM GMT
I'm thinking I reversed my transistors. Will check tomorrow.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
So I'll have to drive it specially. More research.
One question though, is refresh rates. I'm not sure how to change them, to meet the special imac requirements.
Post Edited (Capdiamont) : 4/25/2009 5:54:57 AM GMT
