Is A BS2 able to handle compass sensor and 433Tx?
Hi all,
I am using a bs2 chip for a compass sensor and a 433 tx.
My original idea is sending data from compass sensor via 433 tx.
What a problem I have is that I cannot combine 2 code (one is compass code and the other is tx code) due to "out of variable space" error message.
1> How big is the variable space per bs2 chip?
2> Is adding more·bs2 chips only solution·or is there a other way to do it?
Please help me.
Thank you.
Please help me.
Thank you.
2) Adding more BS2 chips won't solve your problem.
Most code uses some of its variables only part of the time. Some are used for temporary storage during subroutines and never are used to hold information across subroutine calls. These variables can be reused for other parts of the code. The Stamp Editor has the capability to use alternate names for the same variables. Look in the section of the Stamp Basic Manual on "aliases" to see how this is done. That will probably solve your problem.
