My Propeller Doublestack w/cheese
Oldbitcollector (Jeff)
I've been pondering the idea of using a second Propeller as a dedicated sound board.
So I figured that Protoboards would stack nicely, and I was right...
I removed the DC connector, the 1000uf cap, and shortened the height of the power switch.
The bottom board is powered by connecting the 5v/Vss lines connected using male/female pin headers.
The top switch turns on both units and both LED's light.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
OBC
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
8 and 9 are tied together on both sides for prop-2-prop communication.
P10 from the bottom board is routed to the sound circuit with P10 from the top board.
P11 from the bottom board has it's own sound circuit and is now routed from the bottom
to the additional RCA jack on the top board.
I'm really pleased how easy it was to tie these together.
Here's some more shots.
OBC
Thank you for sharing this.
George
Everything is directly connected without issue.
I'm fiddling with FullDuplex serial using HSS audio driver. I'm shooting for a decent
audio output from the bottom board, freeing up most of the resources of the top one for other things.
OBC
