servo connection bd of educ, rev b
i have a bd of educ, rev b, dated 2000-2004. the boe bot manual says there is no 3 position sx, but there is such a sx on this board. also, it says to use only a 6 volt pack to power the servos but the servo headers are 5 volt regulated, vdd, as measured. i have been using a 9 volt battery to power these servos and haven't had any servo problems.
is the manual that wrong? i am looking at page 59, lower right. it also says to use the rev c rules for connection.
thanks,
jim··
thanks,
jim··
I still recommend running the servos off Vin and using a Vin of 6-7.2V rather than 9V. If you can't do that, I'd just pay attention to how hot the regulator gets and possibly add additional heatsinking. If you're using a 9V radio battery, don't. They're expensive and have fairly low current capacity. They don't work well at the high current drains from a motor. You'd be much better off using a battery pack using AA cells (or even AAA cells)
i am actually going to run the servo off a 5v,5amp regulator i made and send the stamp signal to the reg board. it is being powered with a large 12v deep cycle marine battery. i'll be using the same ground for stamp and the regulator though. does that sound good?
jim
I'd use one relatively heavy ground wire to the servo and a separate ground wire to the Stamp and its regulator.
