simple variable question
I have some code, and I was trying to break it up into separate .spin files to make it more manageable. The problem that I run into is that when I move a PUB object to it's own spin file it no longer knows about the variables of the original file. It there anyway to make the other files aware of the variables in the main file, or do I just have to pass pointers? Am I correct that all VAR declared variables live in main memory? Or am I missing something else about this whole thing.
thanks,
Paul
thanks,
Paul
I strongly suggest that you don't divide up code that's all functionally interrelated. It actually make things messier, harder to understand, and often buggier.
Thanks for your response. OK, I think I can make a method in the object to return the value I need. Can you walk me through how calling that method from a different cog gets handled?
thanks,
paul
just take a look into a democode that uses an object.
That's the way it works.
I strongly recommend to keep things that are functionally interrelated together.
Acommodate from the "separate it to thousands of files"-style in C/C++ to
the SPIN-Style which is "ONE file for ONE functionality"
best regards
Stefan
Say you have a main program and a separate object used by the main program.
Say that the 2nd object has a start method that uses COGNEW to start up a new cog using one or more methods in that object. You'd also have some PUB methods in that object that provide the interface to that cog. Look at any of the Spin-only objects in the Object Exchange for examples of this.
Notice that these interface routines either take some parameters, work with them somehow, and end up changing some of the VAR variables in the object that are also used by the routines used by the separate cog or they take some parameters, work with them and some of the shared variables, and return some value.
There's nothing fancy. You just have some variables that are accessed both by the interface routines and by the separate cog's routines.
The trick is making sure that the main program and the interface routines called by the main program don't access or change those variables at exactly the same time that the other cog is also changing or accessing them. One way is to use LOCKxx statements as described in the Spin Manual. In some special cases, you don't need the LOCKxx statements as long as you write your program so only one cog will change a given variable. One common special case is called the Single Producer / Consumer case and is discussed in pretty much any textbook on multi-processor programming.
