Servo project
Hi, I am pretty new to the Basic stamp and was wondering if anyone could give me a little help or pointers
with a project of mine.
I am using a Basic stamp 2 module (BSC-IC) which will be mounted on a Basic stamp 2 carrier board
and want to use it to control two servo motors. I want to program it to move the two servos to a set
position then back again then pause then repeat at random times. The servos want to move to different
positions. Can someone point me in the direction of a tutorial or even better explain here how I can go
about doing this as simply as possible. for example what circuit/program could achieve this.
I dont want to control the servos externally I just want them to run through the program looped to eternity
on the push of a button.
I also have a board of education prototyping board.
Thanks in advance
Tim
Thanks in advance
Tim
The tutorials are found here: www.parallax.com/tabid/535/Default.aspx
