Inductance problems?
I understand the basics of Inductance... how every electronic component has it but its
basically low enough you can ignore it except for a few "problem components".
These components must be isolated or protected from damaging microcontrollers in some
way... IE: an H-bridge or some kind of transistor/driver circuit.
My question is... what all are these "problem components?"
I know so far:
DC Motors (including solenoids)
Relays
What other common components do I need to be worried about?
PS: What about lamps? I've got a couple 6volt 60ma driven by nothing other than a transistor
(emitter follower) and a stamp pin. Do lamps have a problem of inductance?
I know so far:
Relays
The problem is that when you turn off the current flowing through a large inductor, it tries to keep the current flowing. This causes the voltage across the inductor to go VERY high. This high voltage will damage other components. Typically you can just put a diode across the inductor (reverse bias when powered) and this will solve the problem.
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
right? But will this work for relays?
Post Edited (Mike Green) : 12/5/2008 5:18:41 AM GMT
