How to make a servo motor out of 12 volt dc scooter motors & control the motor'
Good Evening All,
I am new to using the basic stamp. I have two 12 volt DC forward/reverse capable scooter motors. I want to covert these two motors into a larger version of a servo motor. The motors have only two wires, a positive and negative wire. This means I need to build a circuit to interface with the basic stamp microprocessor and error control circuit for the motor. I searched on the web for internal servo schematics, but all I've seen are schematics for servo controllers, which I do not need. I need to know how average servo motors are wired internally. Can anyone help me out on this one? Please advise.
//signed//
Mike Simpson
simpsonmichael1@hotmail.com
//signed//
Mike Simpson
Standard servos have a potentiometer on the motor shaft that provides position feedback either to an analog control circuit or, in newer "digital" servos, to a special purpose microcontroller that feeds an H-bridge or similar circuit to actually drive the motor. Have a look at the Wikipedia for articles on servos and R/C Servos.
· -- Carl, nn5i@arrl.net
Understand that my experience with servos is from the CNC world, so when i'm using servos its to move something like a cutting head to a very precisice position.
the second problem is the resolution, depending on how much resolution you want, you may need to find a encoder that can handle your rpm and resolution needs, a 100 final rpm with a 10:1 ratio means the motor is a 1000 rmp motor, a encoder with 20 pulses per revolution would need 33.3 pulses per second resolution, but if you wanted a beter resolution, you could put the encoder on the motor, yeilding 333.3·pulses per second, however you need to be able to register the 3ms pulse gap, some encoders are 200 pulses per revolution at 600 rpm would net a .5 ms resolution, which would be too much for the BS2 to handle, so you must match the encoder pulses to the capabilities of your chip.
_______Just A Thought____$WMc%_____
Mike Simpsonhttp://forums.parallax.com/forums/posticons/icon5.gif
