DVI out from Prop with TFP410? — Parallax Forums
RaymanRayman Posts: 16,383
edited 2009-05-04 02:18 in Propeller 1
It'd be nice to have DVI/HDMI output...
Looking over how the BeagleBoard does it, they use a TFP410 from TI...· Seems like we should be able to use the existing VGA drivers and hook up the output pins to this chip instead of the resistors.·
Not so sure how to generate the clock signal though...
  • johnfl68johnfl68 Posts: 72
    edited 2009-05-02 00:13
    Has anyone had any success with a prop DVI driver/circuit yet???
    John
    Whistler: I want peace on earth and goodwill toward men.
    Bernard Abbott: We are the United States Government! We don't do that sort of thing.
    Sneakers (1992)
  • tonyp12tonyp12 Posts: 1,951
    edited 2009-05-02 03:19
    http://en.wikipedia.org/wiki/Digital_Visual_Interface
    Minimum clock frequency: 25.175·MHz
    Bits per pixel: 24
    DVI/HDMI are digital serial.
    10 bits provided on each of the three data channels.
    With some·external serial shifting and clocking,
    I could see·that possible·5:6:5 can·be done withe the prop
  • AleAle Posts: 2,363
    edited 2009-05-02 05:14
    If the clock can be output and 1 pixel per clock is shifted (to have 640x480 or more syncs but I'm not really sure) that IC could be used directly. The unused bits can be grounded. Of course high-color would be nice but the resolution price is a bit high :-(. We need Prop2 !!
  • RaymanRayman Posts: 16,383
    edited 2009-05-03 00:38
    I've got free samples of the TFP410, but haven't yet found the time to draw up the circuit board... But, my plan is to do as Ale suggests and just use the same resolution as the standard Prop VGA driver (6-bit) and ground all the other color pins. I think it will be an improvement just to have the digital transmission, even if the color depth is the same...
  • OwenSOwenS Posts: 173
    edited 2009-05-03 14:48
    Rayman: Repeat the pins, starting with the MSB. For example:
    Prop -> Chip
    R1 -> R7
    R0 -> R6
    R1 -> R5
    R0 -> R4
    That way you can get the full brightness range
    edited 2009-05-03 21:59
    That's interesting! Have to think about it, but that looks like a good idea.
    visit http://www.rayslogic.com
    if you get this working I am sure you could do well selling as spinstudio module.
    Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
