VFD Display Baud Rate Settings
I am trying to use a GU112x16G-7003 VFD from Parallax.
I ran the demo programs on a Stamp2 no problem.
Now I am trying to run another display (Same type) on a BS2px and the screen is all junk like a bad baud rate setting.
There is no documentation on changing the baud on the display (J0-J3)
The demo program is using 38.4k baud (Baud = 6)
Do I need to change anything for the px?
Alan Bradford
Plasma Technologies
Alan Bradford
Plasma Technologies
I did not bring my stamp manual and I have 49 min left on the manual download.
Im a sorry site for sure...
I hate last minute R&D projects...
Alan Bradford
Plasma Technologies
Parallax Engineering
That Works real good.
Alan Bradford
Plasma Technologies
#SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T9600 CON 84 T19K2 CON 32 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T9600 CON 240 T19K2 CON 110 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T9600 CON 396 T19K2 CON 188 T38K4 CON 84 #ENDSELECTPhil
I have been looking in the Stamp Manual and missed it.
Also in the Demo Programs it shows lines of code to run the VFD, like ( SEROUT VFD, Baud, [noparse][[/noparse]$1F, $28, $77, $10, $01] ).
I dont see anywhere it explains all the elements of the code.
Thanks for the help.
Alan Bradford
Plasma technologies
I had issues with my LCD when I switched to a BS2PX from the BS2, and found this gem.
As to the Serout command.
In the basic manual...
SEROUT {Pin}, {Baud}, [noparse][[/noparse]{commands}]
{Pin} => VFD would be the defined pin that your sending the signal on
{Baud} => from your select and a CONstant defined in your program.
The commands are different based on the LCD,VFD your using, but would/could be defined in your program after reading the VFD manual.
Hope this helps.
Phil
I just got back from a meeting at the customer site, and the manual finished downloading.
I saw the Serial information.
The Noritake web site leaves lots to be desired.
I requested the full data sheet and they will send it in 24-48 hours.
I do have enough information to get this part of the rush job done.
Once again thanks for the help evereyone.
Alan Bradford
Plasma Technologies
