Seven segment display decoder
Hi. I'm using a BCD-to-seven-segment decoder/driver with my BS2 to illuminate digits on a seven segment display (common annode). The driver is active low. I have connected pins A, B, C, D to 0, 1, 2, 3, on my BS2 and I'm using seven 1K resistors. I'm simply using LOW 0, LOW 1 etc to light the segments. I just need to know if the current is being sunk through my BS2 or out of the GND pin of the driver? I was planning on adding more displays and drivers and don't want to exceed the curret limits of my stamp.
I have trouble understanding data sheets
. The data sheet for the driver is here. The part number is 'sn74ls47'.
Post Edited (Aidanx1) : 12/2/2008 12:40:09 PM GMT
. The data sheet for the driver is here. The part number is 'sn74ls47'.Post Edited (Aidanx1) : 12/2/2008 12:40:09 PM GMT
Note that there's a High-level Input Current specified as well, but it's only on the order of tens of microAmps.
Usually these decoders are shared among several LEDs and the Stamp has to feed only one decoder. If you use several of them, you'd need to figure in the load of each of them (1.6mA x # of decoders in parallel). A group of 8 I/O pins on the Stamp can sink about 50mA total with any one I/O pin sinking 25mA.
Post Edited (Mike Green) : 12/2/2008 5:07:20 PM GMT
So the low level current is the current that the stamp will have to sink?
and thats 1.6mA in total for each decoder?... or per pin in use?
Does this mean there is no need for any resistors between A, B, C, D and the Stamp pins?
and its called low level "input" current even though it's actually being sunk out of the decoder?
Sorry if I'm overloading your brain with questions, but what is the high level current you mentioned used for?
