Timing of writing PHSx
Sorry if this is noted elsewhere, but I couldn't find anything via Google using site:forums.parallax.com
I'm trying to output 2 cycle long bit periods back-to-back using multiple counters on multiple synchronized cogs.
As I understand it, writes to PHSx in instructions as dest actually write to shadow memory first which is then latched into the counter.
Q1: If a counter is running, does the first potential accumulate after writing PHSx happen on clock cycle M + 5 (stage 5) or M + 6 (the next stage 1)?
Q2: In NCO / PWM modes, can PINA change immediately upon writing of PHSx[noparse][[/noparse]31] on clock cycle M + 5, or does an accumulate need to happen first?
Thanks.
Thanks.
It looks like PHSA and any resulting pin changes are both written "almost immediately" during the R cycle. Here's a program I wrote to test this:
[b]CON[/b] [b]_clkmode[/b] = [b]xtal1[/b] + [b]pll16x[/b] [b]_xinfreq[/b] = 5_000_000 pin0 = 5 pin1 = 6 [b]PUB[/b] Start [b]cognew[/b](@go, 0) [b]DAT[/b] go [b]mov[/b] [b]dira[/b],[b]dira[/b]0 [b]mov[/b] [b]ctra[/b],[b]ctra[/b]0 [b]mov[/b] [b]frqa[/b],#1 :golp [b]or[/b] [b]outa[/b],[b]outa[/b]0 [b]mov[/b] [b]phsa[/b],[b]phsa[/b]0 [b]andn[/b] [b]outa[/b],[b]outa[/b]0 [b]mov[/b] [b]phsa[/b],#0 [b]jmp[/b] #:golp [b]dira[/b]0 [b]long[/b] 1 << pin0 | 1 << pin1 [b]outa[/b]0 [b]long[/b] 1 << pin0 [b]ctra[/b]0 [b]long[/b] %00100 << 26 | pin1 [b]phsa[/b]0 [b]long[/b] $8000_0000Here's the resulting scope trace:
The delay from writing the first pin directly to writing the second one indirectly via PHSA is 52 ns, or 2 ns (a fraction of a cycle) longer than one instruction time. I repeated the experiment by just writing both pins directly in the same sequence. The delay was 50 ns. So the extra 2 ns definitely comes from writing PHSA and the result percolating to the pin.
'Just a few PropSTICK Kit bare PCBs left!
