Double Size numbers on LCD
Here is a piece of code that I would like to share.
Using a Parallax LCD, and the BOE, I am starting the code for my Scooter Speedometer display.
Comments and critiques welcome.
Phil
Phil
' ========================================================================= ' ' File...... ScooterLCD.BS2 ' Purpose... LCD Control for Scooter program, using customer characters ' Author.... Philip L. Lutz ' E-mail.... phillutz@socal.rr.com ' Started... 18 NOV 2008 ' Updated... ' ' {$STAMP BS2px} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' Routines for handling an LCD. ' ' PrintDoubleSize prints custom characters spanning 2 columns and 2 rows ' Custom character defintions are stored in eeprom to make digits 0-9 as the 4 character blocks ' first digit, second digit ' 0,1 5,6 ' 2,3 7,8 ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T9600 CON 84 T19K2 CON 32 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T9600 CON 240 T19K2 CON 110 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T9600 CON 396 T19K2 CON 188 T38K4 CON 84 #ENDSELECT ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- LcdTx PIN 14 ' serial output to LCD ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- LcdBaud CON T9600 LcdBkSpc CON $08 ' move cursor left LcdRt CON $09 ' move cursor right LcdLF CON $0A ' move cursor down 1 line LcdCls CON $0C ' clear LCD (use PAUSE 5 after) LcdCR CON $0D ' move pos 0 of next line LcdBLon CON $11 ' backlight on LcdBLoff CON $12 ' backlight off LcdOff CON $15 ' LCD off LcdOn1 CON $16 ' LCD on; cursor off, blink off LcdOn2 CON $17 ' LCD on; cursor off, blink on LcdOn3 CON $18 ' LCD on; cursor on, blink off LcdOn4 CON $19 ' LCD on; cursor on, blink on LcdLine1 CON $80 ' move to line 1, column 0 LcdLine2 CON $94 ' move to line 2, column 0 LcdCC0 CON $F8 ' define custom char 0 LcdCC1 CON $F9 ' define custom char 1 LcdCC2 CON $FA ' define custom char 2 LcdCC3 CON $FB ' define custom char 3 LcdCC4 CON $FC ' define custom char 4 LcdCC5 CON $FD ' define custom char 5 LcdCC6 CON $FE ' define custom char 6 LcdCC7 CON $FF ' define custom char 7 ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- ' Define the number 0 CC0 DATA $07,$0F,$18,$18,$18,$18,$19,$19, $1C,$1E,$03,$07,$0F,$0F,$13,$13, $1E,$1C,$18,$18,$0F,$07,$00,$00, $03,$03,$03,$03,$1E,$1C,$00,$00 ' Define the number 1 CC1 DATA $01,$07,$07,$01,$01,$01,$01,$01, $10,$10,$10,$10,$10,$10,$10,$10, $01,$01,$01,$01,$07,$07,$00,$00, $10,$10,$10,$10,$1C,$1C,$00,$00 ' Define the number 2 CC2 DATA $07,$0F,$1C,$18,$00,$00,$00,$00, $1C,$1E,$07,$03,$03,$07,$0E,$1C, $01,$03,$07,$0E,$1F,$1F,$00,$00, $18,$10,$00,$00,$1F,$1F,$00,$00 ' Define the number 3 CC3 DATA $1F,$1F,$00,$00,$01,$01,$00,$00, $1F,$1F,$0E,$1C,$18,$18,$1C,$0E, $00,$00,$18,$1C,$0F,$07,$00,$00, $07,$03,$03,$07,$1E,$1C,$00,$00 ' Define the number 4 CC4 DATA $00,$00,$01,$03,$07,$0E,$1C,$18, $0C,$1C,$1C,$1C,$0C,$0C,$0C,$0C, $1F,$1F,$00,$00,$00,$00,$00,$00, $1F,$1F,$0C,$0C,$0C,$0C,$00,$00 ' Define the number 5 CC5 DATA $1F,$1F,$18,$18,$1F,$1F,$00,$00, $1F,$1F,$00,$00,$1C,$1E,$07,$03, $00,$00,$18,$1C,$0F,$07,$00,$00, $03,$03,$03,$07,$1E,$1C,$00,$00 ' Define the number 6 CC6 DATA $01,$03,$07,$0E,$1C,$18,$1F,$1F, $1C,$1C,$00,$00,$00,$00,$1C,$1E, $18,$18,$18,$1C,$0F,$07,$00,$00, $07,$03,$03,$07,$1E,$1C,$00,$00 ' Define the number 7 CC7 DATA $1F,$1F,$00,$00,$00,$00,$01,$03, $1F,$1F,$03,$07,$0E,$1C,$18,$10, $07,$06,$06,$06,$06,$06,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00 ' Define the number 8 CC8 DATA $07,$0F,$1C,$18,$18,$1C,$0F,$0F, $1C,$1E,$07,$03,$03,$07,$1E,$1E, $1C,$18,$18,$1C,$0F,$07,$00,$00, $07,$03,$03,$07,$1E,$1C,$00,$00 ' Define the number 9 CC9 DATA $07,$0F,$1C,$18,$18,$1C,$0F,$07, $1C,$1E,$07,$03,$03,$07,$1F,$1F, $00,$00,$00,$00,$07,$07,$00,$00, $03,$07,$0E,$1C,$18,$10,$00,$00 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- loop1 VAR Byte loop2 VAR Byte CustomDefn VAR Byte pos VAR Bit digit VAR Nib workVal VAR Word char VAR Byte speed VAR Byte ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: HIGH LcdTx ' setup serial output pin PAUSE 5 Initialize_Lcd: SEROUT LcdTx, LcdBaud, [noparse][[/noparse]LcdCls, LcdOn1 ,LcdBLon] ' Initialize LCD PAUSE 5 ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: FOR speed = 0 TO 99 GOSUB PrintDoubleSize PAUSE 500 NEXT PAUSE 1000 GOTO Main PrintDoubleSize: ' split speed into separate digits FOR pos = 0 TO 1 ' For each digit IF pos = 0 THEN digit = (Speed / 10) ELSE digit = (Speed // 10) ENDIF workVal = digit * 32 ' offset for the custom char definition in EEPROM CustomDefn = pos * 4 ' offset for the custom char definition storage position ' Read/Define Cust Char 0+offset position value FOR loop1 = 0 TO 3 ' for each custom character needed SEROUT LcdTx, LcdBaud, [noparse][[/noparse]((LcdCC0+loop1)+CustomDefn)] ' Begin character defintion FOR loop2 = 0 TO 7 ' 8 bytes, define 8 rows of pixels READ (workVal + (loop1 * 8) + loop2), char ' Get byte SEROUT LcdTx, LcdBaud, [noparse][[/noparse]char] ' Send it to the LCD NEXT NEXT NEXT SEROUT LcdTx, LcdBaud,[noparse][[/noparse](LcdLine1),0,1,4,5] ' Print top part of both digits SEROUT LcdTx, LcdBaud,[noparse][[/noparse](LcdLine2),2,3,6,7] ' Print bottom part of both digits RETURN ' ----------------------------------------------------
My teacher said I need 2 magnets that give a value of 1 and 0 (Obviously) so what he said was to attach a magnet to my wheel and an other on the hanger of my trucks. Then just put the basic stamp underneath my board hooking it up how it's supposed to but I'd like to see my speed after the run since going at high speeds on a longboard and looking at a number instead of looking on the road is dumb I was wondering can the basic stamp record and save data on the fly?
Thing's I'd like to know are like distance traveled, time, average speed, and speed for every second. I know that the basic stamp doesn't hold a lot of info and I don't want to run to a notebook and then look at it or do my run and then figure out I didn't have enough room to save it. I want it to display on a LCD so off the bat I know I need
(1) Basic Stamp
(2) Magnets
(2) Push buttons (To change the view from Time Distance and Speeds)
(1) Bread board
(1) LCD Display
And one last question can Basic Stamps preform under constant vibration and if I wipe out which I will is there any hope for it lasting or is it better to just get a Garmin Forerunner
Thanks.
They will pop a signal when metal is passed by them.
(used to read gear rotation)
Mount the Hall effect on wheel mount (needs to be close to the passing metal)
With programming, you should be able to do all of the items on your do list [noparse]:)[/noparse]
Buttons for toggling the display would be good, but you could also change the display on a cycle.
Show MPH for 5 seconds, then display Distance Travelled, then Time, thne back to mph....
You can protect the Stamp by mounting it in a box, rubber mounted (isolated) to take some of the shock.
Phil
and thanks for the help so far
I have seen other posts, "Data logging" that mention adding EEPROM to your system, thereby increasing the amount your can store.
You need to decide
1. what you want to store
2. how much space a that data sample will occupy
3. how many samples you want in a minute, 5 minutes...
You might sample 10 samples per second, once a second, or once every 5 seconds, it all depends on what you want to accomplish.
Phil
http://forums.parallax.com/showthread.php?p=766989
· -- Carl, nn5i@arrl.net
Are you writing to user-definable CGRAM, this is a "44780"-type LCD?
