IRDA for the Basic Stamp
I'm currently looking at irda communications. The hardware can consist of an IR emitter (IR LED) and IR photodetector. I'd like to keep this as simple as possible and stay away from other chips, and use just the input and output sensors on Penguin Robot. Another Penguin could be the second rx/tx. Is there some simple data communications software for this arrangement?
The code could run on the fast Basic Stamp 2px. I read a lot of material on the web but nothing seems to fit this simple application. There's irda on most robot toys and on many computers. It should be do-able on a basic stamp. So can anyone point me in the right direction with some examples for the stamp? I appreciate this help immensely.
humanoido
humanoido
Perhaps what you're really talking about is not IRDA (tm) but simple Infra-red (IR) data sending and recieving. That can be done fairly simply using an IR-LED with 220 ohm resistor on one side, and an inexpensive IR-Decoder chip on the other -- which I believe the Penguin already comes with for IR obstacle detection.
The BS2 can 'output' a bit with a "FREQOUT IR_Pin, 1, 38500". The other BS2 can recieve a bit with "PULSIN IRDecPin, BitValue". Use a 1 millisecond bit-time for zero, 2 millisecond bit-time for one, and you can do data transmission without further hardware of any kind.
humanoido
